96 ek sedan z6 swap - black smoke, 10 mpg, high idle, stumbles with throttle
Old 10-23-2010, 05:25 PM
fourdoorek's Avatar
Default 96 ek sedan z6 swap - black smoke, 10 mpg, high idle, stumbles with throttle
ok so i have a 96 ek sedan with a z6 swap just bought the car as is well its black smoking gets like 10 mpg has a high idle and revs on start up and stumbles when you barely touch the throttle and it revs to 4k when i plug up the map sensor its running an obd2 harness with a jumper and p28 i need some help to make this thing run right please oh and when i hooked up my jumper and p28 my speedo stopped working on the test run
Old 10-23-2010, 05:36 PM
93egSLEEPER's Avatar
Default Re: 96 ek sedan z6 swap real thinker
Any CELs?
Old 10-23-2010, 06:04 PM
apexi_rsx's Avatar
have you done a 2 wire to 3 wire iac conversion? it still needs to be done the harness will not change this. im running a z6 boosted in my 97 with no problems at all and just passed it through emissions
Old 10-23-2010, 06:09 PM
fourdoorek's Avatar
im not sure if its been swapped or not i will check in the morning but how do i swap them just get a three wire iac?
Old 10-24-2010, 06:51 AM
fourdoorek's Avatar
Default Re: 96 ek sedan z6 swap - black smoke, 10 mpg, high idle, stumbles with throttle
the iac is a 2 wire and the harness plug is a three wire
Old 10-24-2010, 06:56 AM
fv8s's Avatar
do you have a functional o2? its most likely running full rich
Old 10-24-2010, 07:01 AM
fourdoorek's Avatar
i just put in a brand new universal o2
Old 10-24-2010, 07:13 AM
fourdoorek's Avatar
Icon2 Re: 96 ek sedan z6 swap - black smoke, 10 mpg, high idle, stumbles with throttle
but i have never attempted to use a universal o2 before are they legit or garbage
Trunks1331
11-24-2012 10:26 AM
s2k drifter
05-23-2004 09:38 PM
pootie.teng
03-29-2004 10:54 PM
Quick Reply: 96 ek sedan z6 swap - black smoke, 10 mpg, high idle, stumbles with throttle
