94 EX Sedan Refresh: A Series of Unfortunate Events - Page 2 - Honda-Tech
Old 01-05-2017, 09:09 AM   #26
talks to himself
CX-Adam's Avatar
Default re: 94 EX Sedan Refresh: A Series of Unfortunate Events
Quote:
Originally Posted by TomCat39 View Post
Trying to do all that within 5 minutes of laying down the bead of "The Right Stuff" is not the most pleasant. Once done though, you do up the bolts and sigh a big sense of relief.
Truth.
Litre, try it a few times without the gasket maker on. You'll be happy you did.
CX-Adam is offline   Reply With Quote
Old 01-05-2017, 09:09 AM   #27
LiteraCola's Avatar
Quote:
Originally Posted by CX-Adam View Post
I couldn't get the snap ring pliers to work. I used two flathead screw drivers to spread and press the snap ring down onto the bearing. Then I turn the whole thing upside down and, from about an inch off the ground, let it drop onto a 2x4.
I also was having trouble with the snap ring pliers. I needed another set of hands, but in the meantime I spread the snap ring and put a zip tie on the pliers to help hold it in place. I feel like it's definitely possible to spread it too much...
LiteraCola is offline   Reply With Quote
Old 01-05-2017, 09:11 AM   #28
LiteraCola's Avatar
Truth.
True. After 3 times of messing with it and subsequently ruining my gasket maker bead, I decided to oil the bearings and the case and cover it up for the night. That was my plan, but I had to walk away before I threw it outside haha
Old 01-05-2017, 09:22 AM   #29
talks to himself
CX-Adam's Avatar
Quote:
I've been there and then some, dude. At least you didn't put a hole through the case like I did with mine.
Old 01-05-2017, 09:23 AM   #30
LiteraCola's Avatar
Oh my...part of me doesn't want to know how you pulled that off haha
Old 01-05-2017, 12:46 PM   #31
Put the transmission engine side down on the bench like you have it. Set the case on as far as it will go without opening the snap ring, then put two bolts in loosely (on opposite sides). Now when you snap the ring it will slide straight down those bolts and not mess up the sealer.
mk378 is offline   Reply With Quote
Old 01-05-2017, 02:43 PM   #32
Seagull Management
94EG8's Avatar
What you want are lockring pliers, like so:
These make that lock ring stupidly easy. Snap ring pliers on the other hand will drive you nuts.
As for the reassembly. Set the outside half of the case on, even with the snap ring not spread it should go down to within 1/4" of the closing all the way. If it doesn't stick a screwdriver in the hole where where the spring pin (so called bitch pin) goes through the shifter rod and start shifting it while wiggling the top half of the case, normally they'll drop right down. Then spread the lock ring to let it drop the rest of the way. At this point the countershaft bearing still wont quite be seated in the lock ring. To do this you can either use a small prybar with a curved end to pry up on the nut on the end of the countershaft to lift the counteshaft up so it snaps into place, or you can flip the transmission over, hold it about 1" above the floor or workbench and drop it. Both methods work well, I usually go with the first one but I have used both.
Finally, make sure if you didn't already that you actually pull the gears off the shafts and clean everything. Both shafts normally have the oiling holes plugged with debris once you actually get them apart.
94EG8 is online now   Reply With Quote
Old 01-06-2017, 07:02 AM   #33
LiteraCola's Avatar
Well, folks... I used the "turn over and drop" method and everything went together beautifully! Now all I need are my axle seals (should be where sometime next week) and my flywheel (should be here today) and I'll be throwing this bitch back together! Today at work I took the shifter and stabilizer bar apart, sandblasted and painted the stabilizer, installed new Energy bushings, lubed the shifter ball and socket and put it all back together. She's gonna be like a brand new car!
Old 01-06-2017, 07:04 AM   #34
talks to himself
CX-Adam's Avatar
Nice! Glad it went well.
Old 01-13-2017, 10:05 AM   #35
LiteraCola's Avatar
Well, guys... I got the car back together yesterday, got my little baggy with the bitch pin, my punch and the spring clip, emptied the baggy right next to where I was laying under the car... Thirty seconds went by before I went to grab the bitch pin. POOF, gone. It totally vanished. I spent the next hour searching for it; I drug a damn magnet across the grass in a 10' circle and found nothing. I broke down and called the Honda stealership and ordered one, and a dizzy o-ring. So hopefully the car will be running this evening!
Old 01-13-2017, 11:35 AM   #36
talks to himself
CX-Adam's Avatar
We need to come up with a name for that pin to describe what a pain in the *** it is. Oh wait. How many times did you drop the f-bomb searching for it?
Old 01-13-2017, 12:49 PM   #37
Intelligently Stupid
TomCat39's Avatar
Every time I knock the bitch-pin out at the salvage yard to do a motor or tranny pull, I throw it in my tool bag and keep it. I have a few extra bitch-pins just in case I ever lose one like you just did.
Best of luck today.
TomCat39 is offline   Reply With Quote
Old 01-13-2017, 02:40 PM   #38
LiteraCola's Avatar
So I got the car back together; quite a bit of cursing happened, and I was tempted a few times to light the car on fire haha. Anyways. The car runs fine, the Energy shifter stabilizer bushings make it feel so much better than it did! But I'm having some trouble getting her into reverse. Sometimes, it won't go at all. I noticed that if I go to 4th, and then reverse, it helps. But overall, reverse isn't working too well. Any thoughts?
Old 01-13-2017, 06:55 PM   #39
TomCat39's Avatar
It's pretty common. There is no synchro for the reverse gear.
The two tricks I do is put it into 2nd gear, or I just lift up on the clutch pedal for a split second while in neutral so it spins the shaft a little.
Those two tricks always seems to work for me.
Old 01-14-2017, 04:22 AM   #40
LiteraCola's Avatar
It worked perfectly fine before; that's what I don't understand.
Old 01-14-2017, 09:13 AM   #41
Seagull Management
94EG8's Avatar
You may not have had everything lined up and damaged the shift change mechanism when you reinstalled the interlock guide bolt.
Old 01-15-2017, 06:07 AM   #42
LiteraCola's Avatar
Quote:
If that were the case, wouldn't I be having trouble in their gears as well?
Old 01-15-2017, 06:50 AM   #43
Seagull Management
94EG8's Avatar
The one time I did it I only had issues with reverse.
Old 01-15-2017, 07:09 AM   #44
LiteraCola's Avatar
Damnit. So I guess I'll be tearing it apart again. ****.
Old 01-15-2017, 08:16 AM   #45
Seagull Management
94EG8's Avatar
With the transmission out, but still assembled remove the interlock guide bolt and look in the hole, if you see where the bolt has marked stuff up inside you'll know what you did wrong.
Old 01-15-2017, 06:43 PM   #46
LiteraCola's Avatar
Okay fellas. I'm pretty sure I figured out my issue. I tore everything apart, checked the interlock guide bolt hole and everything else looked fine. I "test drove" the trans on my work bench, running through each gear and looking everything over. The trans operates perfectly... Reverse is basically impossible to "test drive"; Gotta have that leverage from the shifter linkage. Check out this picture and tell me what you see....
This is from the first time I tore it apart. Dirty, but everything is correct...
Now look at this one. Does that reverse idler gear look weird to you?
If your answer was, " The reverse idler gear was installed upside down, dumbass!", then you're correct! I even googled images of the trans just to be sure. I guess she'll be going back together tomorrow! The fluid was kinda dirty and the magnet had already picked up some shavings; I assume that's from the few times I tried to force reverse. Whoops!
This time her *** is in the garage and the Corvette is out in the cold.
Old 01-16-2017, 02:28 AM   #47
Seagull Management
94EG8's Avatar
This had crossed my mind, but I wasn't sure if it was actually possible to put the reverse idler in upside down as I'd never tried it.
What are you running for fluid?
Old 01-16-2017, 06:03 AM   #48
LiteraCola's Avatar
I'm running Honda MTF; good thing I bought extra! It makes perfect sense now. If I used TomCat's method of basically double-clutching (or releasing the clutch a little in neutral before trying reverse), it would just barely go in, but as soon as the clutch would start coming out it would grind and pop out. And the reverse gear is a little chewed up on the top (or bottom) side of the teeth.
Old 01-16-2017, 07:41 AM   #49
talks to himself
CX-Adam's Avatar
Man, you got the trans back out quickly. Well done.
Old 01-16-2017, 08:08 AM   #50
tony_2018's Avatar
When you're determine to finish the damn job...nothing gets in your way. Not even a snow storm.
tony_2018 is offline   Reply With Quote
rebuilding 4x114.3 ITR conversion defnu Suspension & Brakes 15 02-08-2016 01:34 PM
HUGE PARTS-OUT CTR EK9, recaro, bridge, spoon, mugen power, kpro, k-tuned, Karcepts, hondastreet For Sale 18 11-11-2013 11:03 AM
LOS ANGELES : FS Custom Honda Ruckus from StandardFunctions. Goal_Kar Southern California (Sales) 10 09-09-2013 10:57 AM
December WTB Sticky boostedcivicsir Drag Racing 32 12-30-2009 02:10 PM
November WTB Sticky boostedcivicsir Drag Racing 30 11-29-2009 06:39 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
