94 del sol ls swap ???????? - Honda-Tech
Old 10-30-2007, 09:59 PM   #1
94_sol's Avatar
Default 94 del sol ls swap ????????
i just bought a 1994 del sol s with the d15. i was wanting to do the ls swap and was wanting to know what was all needed and what needs to be dont to do the swap.
i know i will need
motor
tranny
axels
ecu
motor mounts
shif linkage
can i use the same wiring harness
and the same spindles
please help me out thanks
94_sol is offline   Reply With Quote
Old 10-30-2007, 10:10 PM   #2
sol2hatch's Avatar
Default Re: 94 del sol ls swap ???????? (94_sol)
help yourself
S
E
A
R
C
H
you dont even have to do that, just look at the frequently asked questions thread at the top of the forum.
sol2hatch is offline   Reply With Quote
Old 10-30-2007, 10:47 PM   #3
94_sol's Avatar
could not find any info im the faq's
Old 10-30-2007, 10:53 PM   #4
sol2hatch's Avatar
blasphemy!!!!!!
All it is is a B series swap (aka GSR, Type R, LS, ETC.) Just look at the GSR swap How to in the FAQ, and ignore when it talks about vtec
Old 10-31-2007, 01:38 AM   #5
* B A N N E D *
integra mounts. the entire swpa and shift linkage, ecu from the ls.....have fun
yes stock spindles = fine
suicide_shift is offline   Reply With Quote
Old 10-31-2007, 07:06 AM   #6
94_sol's Avatar
Default Re: 94 del sol ls swap ???????? (suicide_shift)
ok but the faq gsr post did not answer all questions will the d15 wiring harness work for the b18b
Just bought 93 del sol - need feedback on idea for obd1 ls swap with a turbo kdoggparker Honda Civic / Del Sol (1992 - 2000) 1 10-28-2010 12:51 PM
Nead help for h22 swap in to del sol chespi Honda Civic / Del Sol (1992 - 2000) 1 04-05-2009 09:24 AM
Obd0 ZC Motor in 94 Del Sol hugo0851 Honda Civic / Del Sol (1992 - 2000) 5 08-14-2008 08:25 AM
OBD2 LS Motor, OBD1 Honda Del Sol.. what do i need for swap? jaydmej1 Hybrid / Engine Swaps 2 03-22-2004 10:09 AM
Ls motor into Del Sol..... question... COLORPROS Honda Civic / Del Sol (1992 - 2000) 3 04-23-2003 09:37 AM
Tags
del, honda, ls, needed, sol, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
