94 Civic Vtec interference head - Honda-Tech
Old 04-22-2006, 05:28 PM   #1
bukfuddie's Avatar
Default 94 Civic Vtec interference head
hey tried search and nothing! i heard that all hondas have interference heads, is this true? my uncles d16 blew a timing belt with 100k miles on the car, is he screwed? thanks
Ron
bukfuddie is offline   Reply With Quote
Old 04-23-2006, 07:35 AM   #2
bukfuddie's Avatar
Default Re: 94 Civic Vtec interference head (bukfuddie)
no1 knows?
Old 04-23-2006, 07:41 AM   #3
filipedua's Avatar
What you mean with interference heads?
filipedua is offline   Reply With Quote
Old 04-23-2006, 07:44 AM   #4
spoonracer84eg's Avatar
Default Re: 94 Civic Vtec interference head (filipedua)
interference heads will bend valves and all sorts of other bad things when they loose timing. I am not 100% sure but I think that hondas are interference motors. I would just pull the head off and check out the valve train. He might have gotten lucky.
spoonracer84eg is offline   Reply With Quote
Old 04-23-2006, 07:50 AM   #5
egsleepercivic's Avatar
I think you will be ok, I did the same thing on my old D16z6 and I was fine. I think it is kind of luck of the draw on a d series, B series wwill difinetly destroy the head.
egsleepercivic is offline   Reply With Quote
Old 04-24-2006, 06:22 PM   #6
bukfuddie's Avatar
couldi take off the valve cover and turn the timing sprocket by hand to see if I see any smashing? would that work?? any ideas
interference vs non-interference nicoles1618 Honda Accord & Crosstour (2003 - Current) 1 06-14-2016 04:56 PM
interference motor, what all interferes twentyhurtz Acura Integra 9 09-15-2009 11:38 AM
b16a interference or non interference irideslammed5021 Honda Civic / Del Sol (1992 - 2000) 4 10-19-2007 03:46 PM
piston-valve interference??? mattie_96 Honda CRX / EF Civic (1988 - 1991) 6 09-09-2006 11:48 PM
'92 Acura Integra....Quick Question For You. Auto Solutions Acura Integra 17 03-11-2004 04:39 PM
Tags
15, 94, civic, crv, d16, head, heads, honda, inerference, interferance, interference, luck, pull, valves, vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
