PROBLEM PLEASE HELP!!!
Old 04-22-2006, 11:09 AM
wez
wez's Avatar
Default PROBLEM PLEASE HELP!!!
was drinving my car yesterday and noticed a great loss in power. the car even struggled to set off, (sort of felt like it wasn't firing on all cylinders but it was, i replaced distributor, ht leads and sparkplugs today to see if this sorted the problem but didn't)
I removed the oil cap on the rocker cover and loads of smoke kept coming out.
please help someone i need to find out what the problem is, i have a complete spare car in the garage inc engine so sorting the problem shouldn't be a problem. I just cant afford to go to a garage to this checked out has i have no money
cheers in advance everyone!!!!!
Old 04-22-2006, 12:54 PM
wez
wez's Avatar
Default Re: PROBLEM PLEASE HELP!!! (wez)
someone has got to know what smoke coming out of the oil cap on the rocker cover is a sign of???
please help im desperate
Old 04-22-2006, 01:04 PM
Sketch_hs's Avatar
sounds like rings let loose, do a compression and leakdown test
Old 04-22-2006, 01:09 PM
wez
wez's Avatar
Default Re: (Sketch_hs)
probably sound like a dick now but i dont know how to do a compression test. I changed the timing belt the other day and the timing was way out, could the bad timing of caused this???
Old 04-22-2006, 02:25 PM
wez
wez's Avatar
Default Re: (wez)
please help
Old 04-22-2006, 03:56 PM
Syndacate's Avatar
if smoke came out it's possible u roasted the valves...
do a compression test asap
you have to buy teh guage, it plugs into where the spark plug goes, then u have to pump gas and try to start it (w/ all the plugs taken out)
That's a bad descript, but that's the basics, I'm sure wherever you find a compression tester you can find a better explanation
Old 04-22-2006, 04:34 PM
wez
wez's Avatar
Default Re: (Syndacate)
it idles pretty sweet, theres smoke constantly coming out. its only when i put my foot down theres no power and the odd time when trying to set off.
Old 04-23-2006, 12:17 AM
wez
wez's Avatar
48 PEOPLE HAVE LOOKED AT THIS SOMONE HAS GOT TO KNOW SOMETHING ELSE???
Old 04-23-2006, 01:57 AM
Schrader's Avatar
Well first do what was previously stated. And post back.
Old 04-24-2006, 05:22 PM
wez
wez's Avatar
had a compression test done at a garage and all was fine but thats all i could afford to do. Is there any sensors on the car that could be causing the problem???
autowrench07
05-16-2012 11:03 AM
Red-Rag-B18
05-06-2010 02:30 PM
Don Johnson
10-05-2004 10:47 PM
FourthGenHatch
05-22-2003 09:45 PM
Tegra
03-15-2003 08:38 AM
Quick Reply: PROBLEM PLEASE HELP!!!
