94 civic speedometer not working and throwing a check engine light
Old 11-05-2006, 10:19 AM
steelrainwarrior's Avatar
Default 94 civic speedometer not working and throwing a check engine light
My speedometer isn't working and I have already replaced the speed sensor in the tranny. will the cluster not working cause the check engine light to come on? a guy at the shop said it was the speedometer head.
Old 11-05-2006, 10:25 AM
Boosted B6teen's Avatar
Default Re: 94 civic speedometer not working and throwing a check engine light (steelrainwarrior)
Go pull the check engine code and let us know what it is,
Old 11-05-2006, 11:39 AM
EX2SI's Avatar
Default Re: 94 civic speedometer not working and throwing a check engine light (Boosted B6teen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted B6teen &raquo;</TD></TR><TR><TD CLASS="quote">Go pull the check engine code and let us know what it is, </TD></TR></TABLE> yup..... and it still sounds like a vss to me
Old 11-05-2006, 12:16 PM
Default Re: 94 civic speedometer not working and throwing a check engine light (EX2SI)
yeah ill have to go out and check it later but has something to do with it. the check engine light only comes on when I accelerate hard. its not on when I start the car and it will stay off if I keep the rpms low while driving. the speedo never works though the rest of the gauge works fine.
Old 11-05-2006, 01:25 PM
I just checked the codes and it is giving me 17 vss
Old 11-05-2006, 01:33 PM
Are you sure that the new one you put in was in working order? It also maybe be your ECU, the speed signal goes from the sensor to the ECU then to the cluster. I used to throw VSS codes all the time(speedo would still read though), then switched ECUs and never had the problem again.
Old 11-05-2006, 01:40 PM
it was a used one that he had at the shop and they used the gear from mine. my speedo doesn't ever work.
Old 11-05-2006, 03:54 PM
Sol_SiR's Avatar
ha ha ha mine did that too, i changed the speed sensor and its a ok now except it cost me $118. but since i just totaled my civic ill sell you mine for $55 shipped.
Old 11-05-2006, 04:07 PM
Default Re: 94 civic speedometer not working and throwing a check engine light (Sol_SiR)
well the speed sensor shouldn't be the problem since I just had it replaced Ill keep you in mind though
Old 11-05-2006, 04:08 PM
it could have been a crappy used one
Old 11-05-2006, 04:13 PM
Pr0ject93hb's Avatar
its your speed sensor. same thing happened to me. when the chekc engine light came on vtec would not work. so get a new speed sensor. that will do it.
Old 11-05-2006, 04:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steelrainwarrior &raquo;</TD></TR><TR><TD CLASS="quote">well the speed sensor shouldn't be the problem since I just had it replaced Ill keep you in mind though</TD></TR></TABLE>
mine was a "new" one as well and when i would get hard on the gas the light would come on because the sensor was cracked. for a while it the engine light would go on and off. finally it went completely out and i replaced my speed sensor and got my speedometor back. might wanna take it off and look at it. might be a fucked up one.
good luck
Old 11-05-2006, 04:22 PM
Default Re: 94 civic speedometer not working and throwing a check engine light (Pr0ject93hb)
yeah that sounds exactly like what I have going on now. If I get on it hard the cel comes on. Im gonna see if I can get some money back for that sensor.
Old 11-05-2006, 04:25 PM
alright I have a gsr tranny in my 94 I think I need a new vss for the 94 gsr or can I get one for the civic.
Old 11-05-2006, 05:41 PM
I guess Ill start a new post for that cause im changing topic
90civicSiRacer
10-01-2007 02:35 PM
low430
08-28-2005 06:31 PM
Chicano
05-08-2005 08:43 PM
c.dub
03-06-2005 08:49 PM
integrater
05-07-2003 11:52 AM
Quick Reply: 94 civic speedometer not working and throwing a check engine light
