94 civic idle problem - Honda-Tech
Old 05-25-2013, 10:37 AM   #1
Default 94 civic idle problem
Had the strangest problem with my civic for a while. Its a 94 with a 1st gen b16 converted to OBD1. The problem is not while I'm stopped but more so while I'm moving or coming to a stop, mostly when i hit bumps. Coasting downhill and hitting bumps the idle will jump to 1500 or 2000, fall then go right back up again. If I'm in gear and it happens it feels like the car jerks forward even though I've kept the the same amount of pressure on the gas pedal. Living in a city with shitty roads this gets annoying and ruins my MPG's.
Ive searched for vacuum leaks with carb cleaner and propane but i don't believe there is one. I've purchased new ground wires and battery terminals and the battery is not even a year old yet. I'm going to try a new air filter but from there I'm out of ideas. When i had my valve cover open i noticed most of my lost motion assembly's stuck. Would that have to do with anything? I've also done a valve adjustment already.
Any help would be great.
Also noticed this
That nipple has a cover over it and when i remove it the idle moves up a bit then settle back down. Not sure but I would think that it should be connected to something. Any ideas where it goes to.
h0nda n00b is offline   Reply With Quote
Old 05-25-2013, 06:23 PM   #2
Default Re: 94 civic idle problem
Sounds like you might have an air leak between the intake mani and the head. If you have already checked the vacuum lines then check the gasket for leaks. Also check your IACV as well as the FITV. Also get a vacuum line diagram as that could help you find misplaced vacuum line connections.
street93eg is offline   Reply With Quote
Head Gasket problem longjohnsteve Honda Element & CR-V 0 10-09-2016 06:10 PM
d16y7 P0505 again lrhtech Honda Civic / Del Sol (1992 - 2000) 24 03-08-2016 05:00 PM
Accord surging/pulsing idle before warmed up Uncle Ben 1 Tech / Misc 3 12-01-2015 12:41 PM
'94 Civic VX inconsistent idle / hesitation Ozolins All Motor / Naturally Aspirated 1 10-31-2012 09:42 AM
Problem with idling seanreilly08 Honda Accord (1990 - 2002) 3 11-05-2009 05:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
