94 Civic EX oil leak - from distributor shaft or cam seal???
My 94 EX has recently started leaking oil worse (had leaked a tiny bit in past), it looks as if it is coming from the crevice/joint between the engine head and the distributor body.
Has anyone else ever had this problem, if so what do I need to fix it?
Thanx.
Thanx.
1 Post
Re: 94 Civic EX oil leak - from distributor shaft or cam seal??? (Hurricane)
I did, about 5 years ago, I have a 93 Si.
You need #6 on this page, http://www.hondaautomotivepart...EC%29 probably cheaper to go to your local dealer if you consider shipping as well
tvanderpan93
08-21-2012 11:52 AM
