94 civic dx sputter,car turns off ..please help!!=[
i have a 1994 civic dx stock with 160k..has no check engine lights idles normal but when its driven for about at least 10min and traveling around 40mph the car starts to sputter (not aggressive) .i Recently changed the coil pack and this little gray "chip" next to there wired together and it still runs the same, matter of fact the car doesn't want to start now it doesn't crank over or anything after i took it for a drive and parked in my driveway and i let it sit there idling then turned it off and now won't start.ive also replaced the fuel pump and filter...someone please help me im running out of ideas =[
Re: 94 civic dx sputter,car turns off ..please help!!=[
it wont CRANK over at all? if thats the case u need to figure out if your battery is dead or y its not getting power to the starter
it the car lights turn on and u go to start it and it goes "click" check how tight ya bat terminals are, if they seem lose tighten them, if they are as tight as they go a simple screw inbetween them can fix it tho I don't recomend it for very long as it looks stupid but would get the car running if this were the case... to me sounds like your alt is failing tho and the bat is not charging
OrigamiSensei
04-28-2015 07:05 AM
flitcrob
03-22-2011 12:10 AM
Ej1White94
01-09-2011 11:24 PM
