94 Civic DX coupe with D15B7 engine - Crankshaft pulley tool
Old 11-29-2014, 03:01 PM
tomcatter1962's Avatar
Default 94 Civic DX coupe with D15B7 engine - Crankshaft pulley tool
I have a 1994 Civic DX coupe with a D15B7 engine in it. The car has 203178 miles on it. I bought the car back in 2002 for my oldest daughter. The car was wrecked in 2006. The car sat in my yard until this summer. I have done body work and paint. doing mechanical work on it now. Started doing the timing belt today. I rented the crankshaft pulley holder. It has 6pt shape on the tool. I noticed that my crankpulley does not have the 6pt to interface with the tool. My pulley is shaped like a bowl. It has holes around the circumference for the pulley. Any ideas on how to remove the bolt from the pulley bolt from the crankshaft would be greatly appreciated.
Respectfully
Old 11-29-2014, 03:08 PM
Former User's Avatar
Default re: 94 Civic DX coupe with D15B7 engine - Crankshaft pulley tool
Wilmar W89209 Crank Pulley Holding tool - Tools Auto - Amazon.com Wilmar W89209 Crank Pulley Holding tool - Tools Auto - Amazon.com
Old 11-29-2014, 03:12 PM
92ehatch's Avatar
I used an 8mm Allen key on mine. Craftsman the cheap ones bend.
This method will dent the edge of the oil pan where it bolts up Better off with the right tool but this method will work
Old 11-29-2014, 03:26 PM
Default Re: 94 Civic DX coupe with D15B7 engine - Crankshaft pulley tool
Thanks RonJ@HT i will look at the parts stores
Old 12-02-2014, 01:12 PM
PHANTOM MENACE
24TEN's Avatar
You can also try with someone sitting in the car pressing the brake pedal while in park or in gear.
Old 12-04-2014, 11:14 PM
Hysterically Calm
TomCat39's Avatar
Without the aid of the brake booster you really have to have hulk legs to get any real grip on the rotors. Even then it tends to slip or so I found when popping my axle nuts.
For a crank pulley you can't run the car to make use of the brake booster so most likely even with someone mashing the brakes with all their might, it's probably going to not be very effective.
Old 12-05-2014, 09:27 AM
PHANTOM MENACE
24TEN's Avatar
You should know I HAVE hulk legs then. (LOL)
Old 12-05-2014, 09:41 AM
Hysterically Calm
TomCat39's Avatar
Old 12-06-2014, 03:11 AM
To give an update, I ordered the crank pulley holder tool from Amazon, and used it last night. it worked like a champ. No issues. Thanks RonJ@HT and all who responded!
Repectfully
Old 12-06-2014, 10:22 AM
tamboo's Avatar
i just insert a big screwdriver into the brake rotor slot next to the caliper,
pressing on the brake pedal is for the birds (or hulks).
Wytas
10-13-2018 10:19 AM
hcaulfield57
21
07-30-2017 04:55 PM
zrs6v4
02-16-2016 11:57 AM
jonnythan
14
11-27-2008 09:53 AM
TorquelessB16
48
05-24-2006 02:44 AM
Quick Reply: 94 Civic DX coupe with D15B7 engine - Crankshaft pulley tool
