94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams - Page 6 - Honda-Tech
Closed Thread
Old 03-11-2006, 10:24 AM   #126
BlueIntegraBoy's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (crxY-49)
Quote:
Originally Posted by crxY-49
Well why won't the JDM cluster work with your diagram? Do you think it would be just as easy to install?
Thanks
Quote:
Originally Posted by BlueIntegraBoy
NOTE: JDM Integra Type-R clusters will work with these diagrams. Make sure you know which spec cluster you have. 96 Spec will have a catalytic converter icon near the CEL and the 98 Spec do not. Use the 94-97 Integra diagram for 96 Spec and 98-01 Integra diagram for 98 Spec.
BlueIntegraBoy is offline
Old 03-22-2006, 10:10 AM   #127
Nevaeh Speed's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (BlueIntegraBoy)
Any pics of ek clusters into any eg's. Post up.
Nevaeh Speed is offline
Old 03-22-2006, 10:35 AM   #128
Here's a pimp one
Some hybrid hacking going on, but super sweet.
Old 03-24-2006, 08:45 AM   #129
urosch's Avatar
Default Re: -99 EDM ITRcluster in -96 EDM EK3 (NeMoo)
I`ve put 98 ITR cluster in my EK.
But ABS light doesn`t work and also hazard and imobilizer lights don`t work. For hazard light I have done like NeMoo described, but C5 on my cluster is blank. Anyone can help?
urosch is offline
Old 03-24-2006, 10:08 AM   #130
JCL
JCL's Avatar
so for a 98 spec itr you just connect to a 92 hatch by using butt connectors?
JCL is offline
Old 04-26-2006, 04:20 PM   #131
h22 ac's Avatar
I just put in a 98 spec us type r cluster into my 95 integra ls. I followed your instructions and everything works great now except the ABS light. It stays on constantly now. At this time i have the wire for the ABS disconnected, because i don't know where to pin it. your feedback is greatly appreciated.
Mahalo
Henry
h22 ac is offline
Old 04-27-2006, 03:13 AM   #132
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (h22 ac)
Quote:
Mahalo
Henry
The ABS light is integrated into the SRS plug (yellow) for 98-01. It would be in pin A4. The ABS light in your cluster harness is located on the 8th pin of the 16 pin plug. The color of the wire is BLUE/RED. Splice that wire to the A4.
Old 04-27-2006, 01:36 PM   #133
h22 ac's Avatar
wow, mahalo for your expertise. U r a Honda Wizard.
h22 ac is offline
Old 04-27-2006, 04:20 PM   #134
Dark19Acura's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (stackz)
I have an integra automatic 98 with a manuel swap obd1
i want to put the 96 JDM spec cluster in my integra what i need to do??? thank you
Dark19Acura is offline
Old 05-22-2006, 02:07 PM   #135
james88's Avatar
so i just bought an 98-00 itr cluster for my 92 civic. Do i have to use itr connectors? or will any 16 & 13 integra connectors fit?
james88 is offline
Old 05-22-2006, 02:35 PM   #136
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (james88)
Quote:
Preferably from a 98-01 Integra will work the best, prevent more rewiring. You can also get from a 94-97 Integra, but will have to switch a couple of wires. 96-00 Civic plugs will work, but will have to do major rewiring.
Old 05-22-2006, 03:22 PM   #137
james88's Avatar
ok thanks, so im gonna goto the junkyard find a 98-01 integra, cut the wires about 5 inches back. cut my wires and wire them straghit into the teg one and hook it up that sounds right ^_^
james88 is offline
Old 05-23-2006, 02:48 PM   #138
hybridej7's Avatar
excellent info......... might have to go out and get me an integra cluster for my civic.....
hybridej7 is offline
Old 05-25-2006, 07:26 PM   #139
james88's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (hybridej7)
ok, can i use any 16 pin and 13 pin connectors? i cant find any itrs around my area so what other cars can i get them from?
james88 is offline
Old 05-26-2006, 01:39 AM   #140
96-00 Civic or 97-01 CRV
Old 05-26-2006, 03:28 PM   #141
james88's Avatar
thanks brother, ill take a look in the junk yard tomorrow, im sure they got some ******* 96+ civics there.
holla
james88 is offline
Old 05-26-2006, 03:55 PM   #142
Default Re: (james88)
Ok, don't forget to cut like 5 inches of wire off. You'll have to repin the wires around first to the Integra cluster (some wire colors won't match the stock Integra harness).
Old 05-26-2006, 11:05 PM   #143
james88's Avatar
Default Re: (BlueIntegraBoy)
i dont think i can repin them, i think they 92 civics are much fater, i think i will just have to cut them off my harness and connect them to the other one
james88 is offline
Old 05-27-2006, 04:00 AM   #144
No, I meant repin the EK plugs into Integra-like plugs.
Old 05-27-2006, 04:03 AM   #145
thahuhstunna's Avatar
not my thing, but a fine write up nonetheless... well done
thahuhstunna is offline
Old 06-06-2006, 10:02 PM   #146
standinghollow's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (thahuhstunna)
standinghollow is offline
Old 06-07-2006, 11:52 PM   #147
Markis.'s Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (standinghollow)
picked up the cluster 2 days ago im a try my hand at it tomorrow so ill let ya guys no i think the hardest part is gonna be mounting it o yea the cluster i picked up was a 96 ls cluster and u wont believe how much i got it for
Markis. is offline
Old 06-08-2006, 12:19 AM   #148
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (Markis.)
Quote:
Good luck man. Once you do the first, it's easy.
Old 06-13-2006, 09:46 PM   #149
SanSational's Avatar
hey, so ... does anyone know if it's possible to swap a GSR cluster into a 1990 Integra??? I know it's possible, but are there any wiring diagrams?
SanSational is offline
Old 06-13-2006, 09:56 PM   #150
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (90dmintegra)
Quote:
Yes, it's possible. Search the Integra forum for DA wiring diagram. You will need an electronic VSS and run a wire to the ECU. There's a few threads on how to convert to electronic VSS.
Closed Thread
[FAQ] How To Install An Integra Type-R Cluster Into Your Non-ITR Integra (GSR, LS, etc...) BlueIntegraBoy Acura Integra 87 02-13-2014 07:10 PM
[FAQ] DIY 94-01 Integra Maplight in 92-95 Civic BlueIntegraBoy Honda Civic / Del Sol (1992 - 2000) 34 07-20-2010 12:02 PM
Reference for Type-R Gauge Clusters BlueIntegraBoy Acura Integra Type-R 12 05-28-2006 06:49 PM
94-01 Integra Gauge Cluster (GSR/LS Hybrid) With Cut Harness & Plugs BlueIntegraBoy For Sale 16 09-11-2004 12:19 AM
Some Rice And One Nice (hint R) On My Trip To Kona, Hawaii (56K, it's ok, come in) BlueIntegraBoy Honda / Acura 31 08-16-2004 01:48 PM
Tags
92, 9295, 9401, 97, 98, civic, cluster, dc2, diagram, ecu, honda, integra, pieces, s2000, swap, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
