93 del sol wont crank
hi,i just bought a 93 delsol si, it has been siting for 5 years in someones driveway.I pulled the gas tank,put in a new fuel pump,If i turn the key everything cuts on but wont start.no noise at the starter.I can can start it if i run a cable from the battery to the solenoid.any ideals?
Re: 93 del sol wont crank
The clutch pedal has two separate switches if the car has cruise control. You're interested in the topmost stopper/switch.
The main relay has nothing to do with the starter.
Test the clutch pedal switch that presses on the rubber stopper.
donnieb22000
12
10-22-2016 09:13 AM
underpressure02
01-07-2006 02:15 PM
