93 Del sol Targa top Leak Please help - Honda-Tech
Old 05-26-2011, 07:25 PM   #1
Default 93 Del sol Targa top Leak Please help
Hello i have been having an issue with my Targa Top keeps Leaking on me. i Recently bought a new 72320-SR2-043
Genuine Honda WEATHERSTRIP, FR. PILLAR.... Figured this would fix my water issue but as i tested it with a hose the water kept coming in... sigh... i notice that there is still a gap between the Fr. Pillar and the weather stip from the actual targa top. and was wondering if i should just buy new weather strips for the targa top... i have also read something about tightning the targa top but have no idea on how to do this if someone can plz help me i would rather try to tighten the top and see if it makes a better seal then buy new seals and still have to tighten the top ty again plz help hurricane season is coming and im tired of having to get inside my sol and my seats are wet and funky smell...
loki93Delsol is offline   Reply With Quote
Old 05-26-2011, 08:02 PM   #2
DelsolVted's Avatar
Default Re: 93 Del sol Targa top Leak Please help
i have had the same problem with mine and i had to move the glass inward towards the seal and ur able to adjust it but the nut and bolt near the bottom of door below the plastic panel.. its not totally fixed but leaks alot less till i can get some new seals. james.
DelsolVted is offline   Reply With Quote
Old 05-27-2011, 11:40 AM   #3
I have the same issue, but I know in the later years they changed the seal's design so that it didn't leak. Mine is a 93, and my friend had a 97 and his never ever leaked. The 97 had "runners" or whatever you want to call them that ran all the way up the pillar, but mine didn't. So my best advice is to get seals from a 97 del sol instead.
Rikature is offline   Reply With Quote
Old 05-31-2011, 01:44 PM   #4
thanks for the replies ill be ording the new weather strips and hopefully that solves this issue
Old 06-12-2011, 02:02 PM   #5
changed in the weather strips and still get leaks...... all genuine honda parts and sadly im still getting water in thru the passenger side.... its not where the window hits the rubber but more so where the targa top connects with the rubber i put some water on the connection where the targa top is aligned with the rubber and then the water just makes its way in... well hopefully i dont get too much rain and by end of year buy me a new car no point in putting money into a car that continues to leak ..... would not suggest this car to anyone, i can see why it was discontinued
Old 06-12-2011, 02:29 PM   #6
jimmy o.'s Avatar
i would try another targa top cause the top is make of aluminum which over time could probably warp due to chasis flex its worth a shot anyway since all else has failed
jimmy o. is offline   Reply With Quote
Old 06-12-2011, 06:37 PM   #7
Izo
You need to change the Seals on the A and B pillar as well as the ones on the roof for it to stop leaking. Check the bulletin 'dad2bike' quotes:
http://www.teamsolcal.com/forum/view...d5a063#p170195
Izo is offline   Reply With Quote
Del sol targa top leak/trunk question Mylinh Honda Civic / Del Sol (1992 - 2000) 4 12-15-2011 09:10 AM
My Del Sol Targa Top Leaks :( loki2010 Honda Civic / Del Sol (1992 - 2000) 1 11-28-2010 09:33 AM
del sol targa top question Frost_1097 Honda Civic / Del Sol (1992 - 2000) 13 01-16-2007 09:34 PM
Targa top seals Tazragoon Honda Civic / Del Sol (1992 - 2000) 8 10-20-2006 10:04 AM
anyone have hookup for Del Sol weather strip? totalimpact Honda Civic / Del Sol (1992 - 2000) 5 03-04-2004 10:32 AM
Tags
2011, adjusting, commen, crx, del, delsol, hits, leak, seal, sol, stuck, targa, target, top, tops, traga, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
