93 Del Sol low idle and runs a little rough
Old 09-25-2011, 03:08 PM
m.glisson003's Avatar
Default 93 Del Sol low idle and runs a little rough
I took it in to get diagnostics and they said my PCV valve was bad and my alternator was going out. I replaced the alternator and replaced the PCV valve but Im still having the same issues! The car idles very low (around 300-500 RPM) and sounds very rough. And when I give it gas it kind of sputters a little.
Any ideas as to hwhat my issue or issues could be?
Old 09-25-2011, 03:15 PM
The Grumpiest
grumblemarc's Avatar
Default Re: 93 Del Sol low idle and runs a little rough
Do a full tuneup.
Old 09-25-2011, 04:05 PM
Originally Posted by grumblemarc
Do a full tuneup.
I have pretty much done everything a tune up consists of. This is what I've done.
Replaced alternator
Spark plug wires
Spark plugs
PCV valve
Old 09-25-2011, 04:06 PM
What could be some possible reasons why the car is acting this way?
Old 09-25-2011, 04:15 PM
joeshmo's Avatar
Did you check what voltage your alternator puts out now? How is your battery? Any other issues or CEL's?
Old 09-25-2011, 04:27 PM
The old alternator was putting out 3 amps. And when I activated any kind of power the RPMs would drop even lower and the car would almost die! But I replaced that alternator with another one that works fine. But no, I havent checked the voltage of the new alternator. I just had my battery chcecked and thats fine too.
Old 09-25-2011, 04:32 PM
hatchhappy's Avatar
take the distributor cap off and make sure there arent any carbon deposits (brown dust), make sure the points arent corroded on the cap, check the rotor and while you got it open look at the wiring and make sure nothing is burnt, loose or cut if thats all good then get a manual and a multimeter and test the coil and icm. Hope this helps
Old 09-25-2011, 04:39 PM
joeshmo's Avatar
Also replace your fuel filter, just for fun.
Old 09-25-2011, 05:24 PM
akacoke's Avatar
fuel filter , check or replace dizzzy cap and rotor(clean the 4 terminals with a clean wire brush), clean/test or replace IACV, clean TB. make sure the plugs are gaped to spec.
i would check the ignition timing first.
Old 09-25-2011, 07:33 PM
Thanks for all of the suggestions. I will replace fuel filter, distributor cap, and clean my throttle body and get back to you guys with results.
Old 09-25-2011, 07:42 PM
Former User's Avatar
CEL codes?
Old 09-26-2011, 09:06 AM
Originally Posted by RonJ@HT
CEL codes?
The check engine light isnt on. Autozone does not have an OBD1 scanner and schucks does have an OBD1 scanner but doesnt have the adapter for Hondas.
Old 09-26-2011, 09:11 AM
Click the CEL sticky at the top. You can pull the codes with a short piece of wire or a paperclip.
Does the CEL work?
z0mby
17
12-05-2011 09:23 AM
xerokill
09-03-2007 05:59 PM
B2AMMO
03-09-2004 07:59 AM
go2slo96
08-27-2003 07:38 PM
boonacka
01-27-2003 01:24 PM
Quick Reply: 93 Del Sol low idle and runs a little rough
