93 civic - making weird noise while in reverse - Honda-Tech
Old 01-10-2011, 06:23 PM   #1
Default 93 civic - making weird noise while in reverse
i have a 93 civic with a ls motor
heres the issue, the front end is being redone slowly, so far i have done inner and outer tie rods and all new lca and uca bushings. now for the noise, when i got to reverse or turn in reverse, you hear this weird whine and grind. stops right when i stop. only does this in reverse and when i make turns at low speeds. prolly cant hear it while im going cause the car shatters alot still.
anyone got a clue what it maybe? i was thinking my axles...
dfJDM is offline   Reply With Quote
Old 01-10-2011, 07:22 PM   #2
Default Re: 93 civic - making weird noise while in reverse
bump.. anyone got an idea?
Old 01-10-2011, 09:28 PM   #3
civicdelsol33's Avatar
Id replace the wheel bearings next. The axles usually click when you turn and accelerate at the same time.
civicdelsol33 is offline   Reply With Quote
Old 01-11-2011, 06:15 PM   #4
Quote:
hmm, okay, will do
Reverse gear making noise???? C5teg Acura Integra 15 08-04-2008 02:44 PM
whining noise in reverse tommy. Acura RSX DC5 & Honda Civic EP3 3 09-24-2007 01:59 PM
Inner axle poping? b16a1eg6 Honda CRX / EF Civic (1988 - 1991) 9 09-22-2007 09:46 AM
weird noise? axle? whp Honda Prelude 3 02-03-2007 09:08 AM
weird noise bjizzle07 Honda Civic (2006 - 2015) 4 01-06-2007 08:30 AM
Tags
2007, axle, backing, civic, deep, honda, make, makes, noise, reverse, reversing, sound, strange, turning, weird
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
