93 civic ex clutch switch - Honda-Tech
Old 01-16-2010, 09:24 PM   #1
Default 93 civic ex clutch switch
Can anyone tell me if ther is a clutch switch for the hond civic ex and if so where. We just got a wrecked civic ex and the clutch was pushed up and can't be put down far enough down for the car to start We couldn't find a switch to bypass it tho
Jtkdirtbike is offline   Reply With Quote
Old 01-16-2010, 09:30 PM   #2
1320RHD's Avatar
Default Re: 93 civic ex clutch switch
U CAN BYPASS IT
1320RHD is offline   Reply With Quote
Old 01-16-2010, 09:41 PM   #3
Do you know how if you could explain it to me that would be great
Old 01-16-2010, 09:47 PM   #4
Matt93eg's Avatar
Yes, there is a clutch interlock switch. It will be a switch around the clutch pedal area with 2 wires going to it. There is also a cruise control switch on the clutch. I can't remember if the clutch interlock is above or below the cruise. To temporaily bypass it. You can unplug the connector going to the switch and jump the terminals on the plug with a piece of wire.
Matt93eg is offline   Reply With Quote
Old 01-17-2010, 12:31 AM   #5
Oh look, I can change this
deschlong's Avatar
It's above. #2 in the picture.
deschlong is offline   Reply With Quote
06 civic power window issue brent_si Honda Civic (2006 - 2015) 2 09-18-2014 10:11 AM
FS: 1993 Civic EX sedan part out (IL) georgj For Sale 19 12-30-2010 11:38 PM
Urgent! 93 Civic EX Power Window wiring diagram passenger side! Essenar83 Honda Civic / Del Sol (1992 - 2000) 3 12-14-2007 07:35 AM
Power Windows! D16Z6_turbo Honda Civic / Del Sol (1992 - 2000) 2 08-04-2005 10:21 PM
clutch switch under clutch pedal?? 3rdGteg Tech / Misc 6 11-14-2002 08:43 PM
Tags
92, 93, 94, 95, bypass, chlutch, cicic, civic, clutch, del, delsol, honda, location, pedal, sol, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
