'93 Civic DX - Reverse Lights Constantly On
Old 12-08-2007, 10:16 AM
buzz_42's Avatar
Default '93 Civic DX - Reverse Lights Constantly On
I have replaced my reverse light switch. Are there some grounds that are common problems in these cars? What else could I check?
Old 12-08-2007, 10:22 AM
Cln94EG1's Avatar
Default Re: '93 Civic DX - Reverse Lights Constantly On (buzz_42)
Take it out of reverse lol no just pulling your leg my guess cause it happened to me unhook the Positive cable then unhook the switch for a min plug it back in and then plug the battery back on it worked for me idk why
Old 12-08-2007, 10:23 AM
RyanA's Avatar
Unplug the reverse light switch and see if the lights go off. IF they do, it's either the switch (yes, still....) or a piece broken off in the trans or misalignment somehow. If it stays on, it's a short somewhere between the switch and lights.
Old 12-08-2007, 10:29 AM
Duane_in_Japan's Avatar
Default Re: '93 Civic DX - Reverse Lights Constantly On (RyanA)
I will assume that this is a stick shift, I have seen some folks get the reverse switch and the N switch mixed up and changed the wrong one, sorry for asking, did you get the correct one. It only takes an ohm meter to test the switch with it unplugged, test it in R and in any other gear or N.
Old 12-10-2007, 12:39 PM
buzz_42's Avatar
I got the one that screws into the transmission
Old 12-14-2007, 04:45 PM
RyanA's Avatar
Default Re: (buzz_42)
Uhhh...... Last time I checked, these cars don't have a neutral safety switch on the trans. LAWL!!!
Old 04-01-2008, 04:06 PM
almightyrock88's Avatar
Default Re: (RyanA)
i have the same problem...but with just the left one that stays on and both dont work when put on reverse.
RACERX72
05-31-2010 08:10 PM
iCollectStraws
Transmission & Drivetrain
11-30-2009 10:00 AM
SigmaOmega
07-17-2005 06:55 PM
PokeyD16Z
01-20-2005 03:18 PM
BlazinITR
01-24-2003 01:05 PM
Quick Reply: '93 Civic DX - Reverse Lights Constantly On
