Bleeding a clutch
Bleeding a clutch
Hey guys, my clutch pedals's spongy as a ****. I thought it was the clutch but it turns out that the clutch need to be bleed. I currently have a jdm b16a with cable trans in a eh2/eg6 hatch. Can you guys help me with a guide on how to bleed the clutch on a cable trans?
Re: Bleeding a clutch
u don't bleed a cable clutch there is no cylinder being pumped with brake fluid to bleed. u have to adjust ur cable by tightening it up with the plastic nut by the clutch arm on the transmission
I am not familure with that model, but some clutches have a cable hydralic combo. Should this be your case you would have a bleed valve at the slave. Blleding Honda clutch systems is tiedious, but pressurizing the tank REALLY helps
Ricextacy
01-18-2012 09:12 AM
Speed_69
04-21-2006 11:00 AM
InJ3cted
05-24-2005 02:16 PM
GreenMachineRex
05-04-2004 06:22 AM
