check engine light on, code 3 even after replacing MAP sensor....
Old 10-13-2011, 11:37 AM
chucky86's Avatar
Default check engine light on, code 3 even after replacing MAP sensor....
i had a 94 ej1 that was running perfect, no check engine lights and i used to get 30+ mpgs before it got rear ended. i swapped everything to an eg6, after and after everything was transefered over to the eg6, i turned on the engine, idle was at 1500 rpm and the check engine light was on. ran the code, it came up as code 3 (MAP sensor). i replaced the MAP sensor and turned on the car and rpm's were still @ 1500, check engine light was on; checked the code and it still comes up as code 3 (MAP sensor). what else could be wrong with the car???i already changed the idle air control valve thinking that would affect the idle speed but it didnt...
Old 10-13-2011, 11:51 AM
virgineg6's Avatar
Default Re: check engine light on, code 3 even after replacing MAP sensor....
Everything was swapped over from donor car? Wire harness, ecu?
Old 10-13-2011, 11:53 AM
motegicivic's Avatar
Did you check the wiring up to the MAP sensor, for splits, cracks etc.
Old 10-13-2011, 02:46 PM
chucky86's Avatar
yeah, everything was swapped over... i checked the wiring harness and it looks fine, im probably going to take off the tape and get a deeper look into the wiring to the MAP sensor. but, one thing that i found out after posting this, was that i should check the intake temp sensor... do you guys think its that?? cuz i already spent like $70 on that new map sensor and its not that...
Bswapped
06-20-2015 02:22 PM
oakman513
07-24-2011 09:31 AM
TheIceMan
12-05-2005 10:44 AM
Quick Reply: check engine light on, code 3 even after replacing MAP sensor....
