93 civic 1.5 NO SPARK NO FUEL
#52
Re: 93 civic 1.5 NO SPARK NO FUEL
i know its the wrong year but i have a 90 ef civic hatch with a b16 swap doing the same thing it ran but died on me on the side of the road does anyone know where the fuses i need to check are at on an ef.......i know everything works cause my buddy has the same car and all of my items work in his car and the problem still happens when i put all of his stuff in my car (dizzy, ecu, main relay, ....) please any help is appreciated
#55
I to have this problem no pump no spark however i haven't changed anything yet. i have checked the fuse and cleaned up the earth. for some reason my dash fuse box only goes to 23 there is no 24 or 25??? but i be leave this doesn't matter because i have power to terminals 1 and 5 and if i jump ether of them with 7 the pump runs.
ideas Main relay? dizzy? Ignition switch ? and the things in reading but no one posts the final solution
#56
The Grumpiest
hi
#57
...no pump no spark however i haven't changed anything yet. i have checked the fuse and cleaned up the earth. for some reason my dash fuse box only goes to 23 there is no 24 or 25??? but i be leave this doesn't matter because i have power to terminals 1 and 5 and if i jump ether of them with 7 the pump runs.
If you have a 92-95 Civic with the stock ECU and wire harnesses, then do this test:
Unplug ECU connector A.
Turn key to ON(II).
Ground pin A7 or A8 in the unplugged connector.
Does the fuel pump always run as long as you keep the pin grounded?
#58
Sorry
Guys it's a 93 GLi. 1.5l auto
The problem is intermittent right when I was about to give up for the day I flicked the Ignition on and off a couple of times. The second time I herd the pump prime and it started I moved it into the garage and turned it off then tried to restart it no prime no spark. Turned it on and off a few more times 3 rd time it primed and was able to run.
Seems like the relay but does that shed anymore light?
Should I still do the test above ?
#59
Sorry
#60
same here. i have a 94 civic dx automatic 1.5. no spark no fuel. changed ecu changed dizzy changed main relay changed ignition switch and all fuses check out good. i am at my witts end. spening too much money on this....any other suggestions??
#61
I followed this post because I have no spark and no fuel, new distributor, known good ecu, and known good main relay
I have power at pin 5 and 7.
Jumping them ttogether does not prime fuel pump, when the key is on.
Fuse 24, and 13 are good.
Next step?
Again I have power aat pin 5 and 7 on the main relay connector and no other pin
Next step?
n15sk4
07-13-2020 04:41 AM
Panoply
14
09-22-2011 03:41 PM
cydinthegreat
15
08-24-2011 03:55 PM
b16hatch620
09-19-2010 06:42 PM
