92 timming belt
Old 10-18-2006, 07:12 PM
Dave P's Avatar
Default 92 timming belt
How tough is a timming belt replacment on a 92 Civic?
Thanks
Dave
Old 10-18-2006, 07:13 PM
WhiteOnRice's Avatar
...Easy enough. Is that all?
Old 10-19-2006, 03:06 AM
Dave P's Avatar
Default Re: (fizix_skate)
Ok , guess I'll get into it.Any tips to make this job easier ? Any photo step-by-step instructions on line?
Thanks
Old 10-19-2006, 03:22 AM
attentionwhore's Avatar
Location: ...and then along comes the fcuking policia, PA
Default Re: (Dave P)
https://honda-tech.com/zero...age=1
search also works
Old 10-19-2006, 04:55 AM
dohcdelsol93's Avatar
Default Re: (attentionwhore)
the only hard part to a timing belt change is breaking the crank pulley bolt. Just make sure you torque it when you re-install it and add some blue loctite. Other than that remember to replace your tensioner and water pump while your in there.
Old 10-19-2006, 05:13 AM
EG2Driver's Avatar
Default Re: (dohcdelsol93)
its just a pain because of the little room you have to work with, unless the engine is out of the car. Also make sure to get a new bolt for the tensioner, its kinda soft.
Old 10-19-2006, 05:45 AM
ddd4114's Avatar
Default Re: (DeadEnd9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 &raquo;</TD></TR><TR><TD CLASS="quote">its just a pain because of the little room you have to work with</TD></TR></TABLE>
yup...a REAL pain
If this is your first timing belt change, expect to spend a day on it, but it really won't be that hard. Any problems you have will be (as stated before) with the crank pulley bolt. Just make sure you have a nice long breaker bar and quality sockets, and you should be fine.
Good luck.
Old 10-19-2006, 09:22 AM
nighttrain33's Avatar
Default Re: (ddd4114)
Obviously no need to drain the coolant if you are not changing the water pump. Also, you don't need the crank pulley on to get the timing right. There is a mark on the crank spocket that can be aligned with a mark on the oil pump to indicate TDC with the crank, and then make sure that the cam is at TDC as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">
yup...a REAL pain
Good luck.</TD></TR></TABLE>
Um, yeah. It took me a while to replace my oil pump. Of course there is more to it than just this, but even just getting to the point of taking the timing belt off took a while. Now I could replace the water pump, oil pump, and timing belt in about an hour.
-Shane
96Miata!
10-24-2016 03:48 AM
kit50si
08-14-2007 09:31 AM
Jdmglenn
01-03-2005 05:52 AM
Shady Hills
07-24-2004 09:40 PM
DEVIN22CBR
08-12-2003 09:19 AM
Quick Reply: 92 timming belt
