92 civic si -- power steering pump leak and whine
Old 11-19-2014, 03:32 PM
swizz977's Avatar
Default 92 civic si -- power steering pump leak and whine
1992 civic si stick motor z6
ok so i was driving and noticed a bad smell and my power steering is leaking everywhere from here
the 2 10s are tight so im not sure how its leaking unless theres a gasket in between?
Old 11-19-2014, 03:41 PM
swizz977's Avatar
Default re: 92 civic si -- power steering pump leak and whine
could it be this little o ring went bad?
Old 11-19-2014, 03:42 PM
Former User's Avatar
08 member with many threads and still fails to comprehend the critical importance of car information.
Old 11-19-2014, 03:53 PM
swizz977's Avatar
ahh im sorry edited
Old 11-19-2014, 04:02 PM
Yeah, replace the O-ring.
Old 11-19-2014, 04:33 PM
swizz977's Avatar
ok do i have to go through honda because im calling auto parts stores and they cant find it
Old 11-19-2014, 04:36 PM
If you can buy it from Honda, do that. Otherwise, see if you can find the right size at Sears Hardware.
swizz977's Avatar
also on the honda parts website it said 11x1.9 not 13
Old 11-19-2014, 04:38 PM
Post the link.
Here's what I found:
Old 11-19-2014, 04:41 PM
swizz977's Avatar
Honda Automotive Parts
Old 11-19-2014, 04:52 PM
I think I was looking at the wrong hose connection.
Old 11-19-2014, 05:24 PM
swizz977's Avatar
is the 11 inner diameter or outer diameter??
Old 11-19-2014, 05:41 PM
I believe it's inner diameter.
Old 12-20-2014, 04:10 PM
swizz977's Avatar
Default power steering whine on cold start
my 92 civic si whines bad from the power steering pump bad for a while on a cold start for some reason..
im not talking about when i turn the wheel im talking about when i just start the car not doing anything..
Old 12-20-2014, 04:11 PM
The Grumpiest
grumblemarc's Avatar
Default Re: power steering whine on cold start
Wait. Do you, or do you NOT have a thread going about a power steering pump leak? Jeez.
Old 12-20-2014, 04:15 PM
92ehatch's Avatar
Source of whine pin pointed. Low ps fluid equals whiny.
Old 12-20-2014, 04:44 PM
Related threads merged. OP - You are allowed only ONE thread per topic.
Old 12-21-2014, 11:42 AM
swizz977's Avatar
Default Re: 92 civic si -- power steering pump leak and whine
oh no i fixed the leak it was a little o ring.. this is different.. i have power steering fluid full
it just makes a bad noise for about 10 seconds on a cold start
Old 12-21-2014, 05:13 PM
The leak may have killed the pump.
Old 12-21-2014, 05:16 PM
92ehatch's Avatar
Did you properly bleed air out of the system when you fixed the leak? Is it foaming when cold?
Old 12-21-2014, 05:37 PM
On vacation
testify's Avatar
The noise is the drive belt squealing.
Old 12-21-2014, 05:47 PM
92ehatch's Avatar
That's an awfully confident answer for someone sitting in front of a computer and not under the hood of the ops car.
Not a bad suggestion but to say it is the problem...
Old 12-21-2014, 05:53 PM
I never narc'd on nobody!
NotARaCist's Avatar
It could be the belt, it could be the pulley bearing, it could be the pump. When replacing the pump, it's always a good idea to replace the belt as well, so the logical course of action here would be to replace the belt. If that doesn't solve the problem, then replace the pump.
Old 12-22-2014, 04:30 AM
On vacation
testify's Avatar
Aren't you sitting in front of a computer too? Who are you to say it ISN'T the problem?
You guys have never heard a drive belt squeal for 10 seconds on start up in the winter?
If the noise lasted more than 10 seconds, that would be different.
A pulley bearing would be noisier, and correct me if I'm wrong, but there are no tensioners or idler pulleys on the PS belt, just crank pulley and PS pulley, so it's not a bearing or a pulley.
If the pump was sucking air and cavitating, again, that would not get better after running the car for 10 seconds.
It's possible that noises can subside once things on the vehicle warm up, but that won't happen in 10 seconds on cold start up.
The only thing that makes sense is the belt.
Old 12-22-2014, 04:52 AM
I think the belt is certainly worth considering but other causes are possible as well.
Quick Reply: 92 civic si -- power steering pump leak and whine
