92 Civic Sedan 5spd *weird noise*
Old 12-23-2008, 08:08 PM
arrocha87's Avatar
Icon2 92 Civic Sedan 5spd *weird noise*
i just bought a 92 civic sedan with a manual 5spd, 121,xxx miles. Its been a while since i drive a stick so im a little confused. its making a rattling sort of noise when the clutch pedal is not pressed, as soon as i step on the clutch it stops. i remember something about a throwout bearing?? am i thinking in the right direction? also it sounds like something is grating when im accelerating in gear. if i dont accelerate, even if its moving, it doesnt make the noise. could it be its missing gear oil? clutch/flywheel? i dont think its the flywheel because it would have trouble starting right? this car was sitting since January 07 so maybe it just needs to be driven? i bought it on friday for $800 so i know ima have to invest some $$ in it. As soon as i got it titled and registered yesterday i dropped the tank and cleaned it out and added like 6 gal of premium gas and it started right up and idled great. a/c and heat work great too.
edit: heres a clip of the noise. video is dark but u can hear the sound. this is inside the car too. im in the drivers seat.
UPDATE: 2/16/09 Finally bought flywheel and clutch. check post #37 for details and pics.
on sunday 12/28 i plan on doing: ngk plugs and wires, oil and oil filter, drain and fill gear oil, air filter, fuel filter, and goodyear gator belts. anything else i should do now?
Old 12-23-2008, 08:29 PM
civicgsr499's Avatar
Default Re: 92 Civic Sedan 5spd *weird noise*
idk about rattling, but i know my trans makes a whining noise with ur foot off the clutch pedal, but once u press it in, it goes away. that would be the input shaft bearing. try and post a video up
Old 12-24-2008, 03:22 PM
arrocha87's Avatar
Icon2 Re: 92 Civic Sedan 5spd *weird noise*
yes thats how it happens but its not a whining, its definitely a rattling sound. i thought it was the engine knocking thats how loud it is! but as soon as i press the clutch in it stops 100%.
*ill put up a video after xmas. well probably tommorow cause we do all our xmas stuff today at midnight.
Old 12-24-2008, 03:29 PM
Anon51's Avatar
pilot bearing probably. do a clutch swap and you'll find out real quick.
Old 12-24-2008, 03:30 PM
Lambo123's Avatar
im pretty sure if the noise occurs when the clutch pedal is depressed and not engaged, you most likely need a new throwout bearing...
Old 12-24-2008, 04:09 PM
arrocha87's Avatar
thats what i was thinkn too but its a real loud rattling, like real loud. and when im accelerating the scraping noise? even if its moving at any speed but not accelerating it doesnt make the scraping noise. i would post a video today but i took out the batt cause it was bad and cracked. is the throwout bearing something i can changeout or is it easier to get another tranny? especially since im goint to be doing a stage 2 and light flywheel soon.
any chance it could be axle related? they dont click when i turn tho...
where can i get a 92 civic fsm? i know a site but its only nissan/infiniti fsms
Old 12-26-2008, 05:29 PM
TurboPWR4's Avatar
I'am having the same noise coming from mine...1992 Civic Lx with 200,xxx on It...Its not affecting any of the performance or gas mileage!!! Just like you described the same thing like a scraping noise...lol...future wise I want to slove this noise!!!
Old 12-26-2008, 08:45 PM
arrocha87's Avatar
i think the scraping noise is something with my flywheel/clutch which im replacing in january.... but the rattling was way too loud to be the throw out bearing and my mngr told me to check the shift linkage and sure enough they are loose as hell!! i already bought my stuff for my tune up tonight so tommorow ill tune it up and fix the linkage. ill video a b4 and after so ya can hear the sounds tho.
Old 12-27-2008, 02:07 AM
TurboPWR4's Avatar
Good Ish!!! Thanks, now once you figure urs out Imma get right onto mine!!! Sometimes It bothers the sh*t out of me!!! Its my DD...
Old 12-27-2008, 05:20 PM
arrocha87's Avatar
i added a video clip to my first post. plz help out guys. cause the linkage is loose but this sounds worse...
Old 12-27-2008, 08:02 PM
arrocha87's Avatar
anyone
arrocha87's Avatar
any1 got their 0.02?
Old 12-27-2008, 08:20 PM
GTlvr82's Avatar
You're no n00b! I would buy a replacement clutch off of ebay. You can get an OEM EXEDY Replacement Kit for around 101 bucks shipped. It comes with clutch disk, pressure plate, and throwout bearing. The OEM clutch that comes with your car from the dealer was an Exedy...
Old 12-28-2008, 03:12 AM
TurboPWR4's Avatar
I have the same sound coming from mine F*ck!
Old 12-28-2008, 07:05 PM
arrocha87's Avatar
2 Qs. 1. is a release bearing the same thing as a throwout bearing? cause thats what some kits list and dont mention a throwout bearing.
2. should i go ahead and throw in a light weight flywheel if ima change my clutch?
Old 12-28-2008, 08:17 PM
arrocha87's Avatar
Old 12-29-2008, 01:58 PM
arrocha87's Avatar
bump. need to order clutch kit ppl.
Old 12-29-2008, 02:08 PM
Resident Gearhead
BryanM.'s Avatar
My .02: I think your clutch is toast.
Clutch release bearing = throwout bearing.
As for the flywheel, that's up to you. Atleast get your current one resurfaced.
Old 12-29-2008, 02:35 PM
Seagull Management
94EG8's Avatar
I'm on dialup so I didn't bother to look at the video. However if its making noise with the clutch out its not the throwout/release bearing, which only turns when the clutch pedal is depressed on hondas, some vehicles (chev S-10s I believe have a throwout bearing that turns all the time) Its far more likely that the transmission input shaft bearing is bad.
Old 12-29-2008, 08:51 PM
arrocha87's Avatar
is valvoline gear oil 70w-90 fine for the tranny?
Old 12-30-2008, 07:02 AM
Seagull Management
94EG8's Avatar
No. Honda MTF or GM/penzoil syncromesh. 10w30 if nothing else.
Old 12-30-2008, 01:10 PM
arrocha87's Avatar
Icon6 Re: 92 Civic Sedan 5spd *weird noise*
will it damage the tranny or is it just not the preffered type?
*and an update on the weird noise.... i realized when i let the clutch engage very slowly (taking foot off pedal slowly) it does not make any noise at all. also the engine was leaking from the dizzy i think and it was all over the tranny engine joint, could that have damaged the clutch and thats where all the weird noises are coming from? im sorry if i ask alot but i dont wanna replace the clutch and flywheel and then have to come back again and drop everything to change the tranny cause it was the input shaft.. if its the input shaft i prefer to buy another tranny from a local shop for $100.
Old 12-30-2008, 03:20 PM
arrocha87's Avatar
will the valvoline make the tranny go ??
Old 12-30-2008, 05:00 PM
Seagull Management
94EG8's Avatar
Its too heavy, like far too heavy, it will shift like crap when its cold, and will probably start grinding from the syncros not being able to slow down fast enough during shifts. Its not like honda MTF is all that expensive.
Old 12-30-2008, 05:15 PM
arrocha87's Avatar
ooh ok. i was jus asking cause i already have the valvoline in my garage. i guess ill buy some syncromesh or go to the dealer... but i hate going to the dealer... waaah! lol
Quick Reply: 92 Civic Sedan 5spd *weird noise*
