92-95 Civic Sunroof
Old 12-02-2009, 10:00 PM
dvs94Teg's Avatar
Location: NORCAL Salinas Valley to Monterey Bay Area 831 CA
Default 92-95 Civic Sunroof
Are the sunroofs on the Eg Coupes the same as the ones found on the Eg Sedans? Is there a write up on here somewhere that shows how to replace the sunroof. I might be buying a sedan that has a damaged sunroof. Any positive input is greatly appreciated. Thank you in advanced.
Old 12-02-2009, 10:25 PM
dvs94Teg's Avatar
Default Re: 92-95 Civic Sunroof
bump
Old 12-03-2009, 04:32 AM
1badascivic's Avatar
YES
Old 12-03-2009, 06:58 AM
dvs94Teg's Avatar
Is there a detailed write up on H-T on how to properly remove and install a sunroof and maybe even the sunroof motor?
Old 12-03-2009, 09:09 AM
crazycornuts's Avatar
yea mines kinda slow and seems to be sh*tin out i would like to know as well
Old 12-03-2009, 02:16 PM
95itr-ej2's Avatar
I dont think they are the same, for one reason the civic coupe eg sunroof when you open it back it opens outside the car and the civic sedan eg opens into the head liner
Old 12-03-2009, 03:41 PM
JNocon's Avatar
Have you tried looking into the DC sunroofs?
Old 12-03-2009, 04:05 PM
Koopa Troopa's Avatar
Take the head liner off, there's like 4 10 or 12mm bolts holding the sunroof on
Old 12-04-2009, 05:31 PM
95Sol99civic's Avatar
I know that 99 EX sunroofs are a different size than the eg stype some ******* put in my 97 hatch. That will be a converstion for me come spring time.
Old 11-11-2022, 10:14 AM
95EGSedanNoob's Avatar
Name says it all, got a 95 Lx and sunroof clicks heavy when trying to open. Looking for replacement cables or more information. 🥴🙏
Old 11-12-2022, 05:16 PM
Oh look, I can change this
deschlong's Avatar
^ LX has no sunroof. Check if it's aftermarket.
Also, sedan and coupe/hatch sunroofs are different.
Old 11-13-2022, 03:42 AM
vin, when registered, came out to be lx, which civic has sunroofs🤯. And which one had bloody cup holders 😤( different pet peeve)... Looking for cable assembly for the sunroof. Any way to tell which sunroof is what?
Old 11-13-2022, 01:42 PM
deschlong's Avatar
For sedans, EX-V in Canada, EX in USA. Where are you in the world?
Old 11-16-2022, 04:54 AM
Live in the states, east coast.
So Lx does not come standard with sunroof🙄.
​​​​​is putting one aftermarket normal?
Old 11-24-2022, 04:39 PM
deschlong's Avatar
Normal, no. But it did happen that some people wanted a leaky hole in their roof! (Do not recommend.)
If it's giving you trouble, clean it then grease it up first!
Old 11-25-2022, 05:31 PM
punk0mi's Avatar
The hatch and coupe use the same size glass, however their frames are different and use a different motor. The sedan is smaller over all and opens differently if I remember correctly.
I just rebuilt my EG SI Sunroof....it's not the worst thing in the world but does take some adjustments to get it just right.
Old 11-25-2022, 09:42 PM
B00STD's Avatar
how did you rebuild it exactly? I need to do this as well any pointers? Parts list?
Old 11-27-2022, 01:28 PM
punk0mi's Avatar
Well, mine just came off "track" so I dropped the entire sunroof frame and disassembled it. Cleaned it. Lubricated the **** out of it. Reassembled and realigned.
There are no parts for these anymore. In fact, I have two broken stop clips (these are the zig zag looking clips in the front of the rails. I ended up reusing the clips, but used some small pieces of metal to serve as the clip stops. I was thinking of trying to find a clip that was in good condition and 3D scan/print some new ones.
The only thing I will tell you, is go VERY slow taking it apart. Take pictures of everything. Grease everything. Follow the FSM on realignment procedure.
Gunmoto
24
06-05-2020 08:17 PM
nikke21
01-06-2007 12:53 AM
nathanong87
08-12-2006 09:32 AM
soundman
06-10-2004 07:47 PM
Quick Reply: 92-95 Civic Sunroof
