92-00 Honda Engine Swap Wiring Guide VTEC AND NON VTEC
#101
Re: 92-00 Honda Engine Swap Wiring Guide VTEC AND NON VTEC
you think the iacv code is causing it to cut off after 5 seconds? im wondering if the fuel is being cut off. have to run some tests...
#103
#104
okay, i have a obd2b y8 in my ob2a hatch, I'm using my obd2a harness and just adding in the vtec wires, will i be able to use the 96-98 p2p ecu?
#108
Hey I'm kind of new to this honda swapping game, I know somewhat about it but I get stuck sometimes, I'm swapping a obd2a motor with obd1 dizzy and alternator, into a 96 civic Dx, which is currently swapped with a d16z6, could I use that harness to swap the jdm b18c? I'm guessing all I would have to do is add the knock sensor? If so is it just one whole wire going from knock sensor to ecu plug? Might be all I need to get the swap done soon. Appreciate it
#109
Technical Hero
What ecu are you using? So the b18c1 has an obd1 distributor and alternator? Are the injector plugs and distributor plugs on your current engine already converted to OBD1?
#110
I'm going to use a chipped p72 that came with the motor, it was on 94 integra, so it got everything changed for plug and play. On my current engine, yea. For both alternator and distributor.
#112
I have a 96 dx civic hatchback and want to do a b16a2 swap. I already have an obd2a ex harness but my question is about the secondary o2. The ex engine harness only has 1 o2 sensor plug, where is the other? I'll be using an obd1 ecu with jumper harness but when i need to get emissions I just want to plug in a obd2a ecu and pass with no problems
#114
Technical Hero
#116
Technical Hero
#118
HELP!: I have a question about putting a obd2a Y8 intake manifold on a obd2b civic and y8 engine. I know some have had issues with that scenario in reverse because of the injection ports. But will I have issue using a y8 IM without ports with an engine with those ports? Please help.
#119
Technical Hero
The only difference is the intake manifold and gasket. If you're using the 96-98 manifold then you must use the 96-98 gasket. There's no difference in the heads at all.
#120
Ok, I ask because I hear some had to block off the little hoses that are above the intake ports on the 99-00 intakes. Wasn't sure if I would have some issues with those holes with a 96-98 intake on a 99-00 Y8. Thanks for your help.
#122
I swapping my 2003 civic ex vtech 1.7L engine for the exact same motor. My engine blew. Will the wiring above apply to my situation or have they changed dramatically from 2000-2003?
#124
1. your gen goes from 2001-2005, so wrong thread bud. 2. if your swapping your 1.7 for the same thing then its just simple plug and play.
