92-00 Honda Engine Swap Wiring Guide VTEC AND NON VTEC - Page 3 - Honda-Tech
Old 09-18-2013, 04:40 PM   #51
Swamp h22 civic's Avatar
Default Re: 92-00 Honda Engine Swap Wiring Guide VTEC AND NON VTEC
I have the z6 swap in my 96 civic and it will not run I have spark and fuel pressure so im assuming my jumper harness to the dizzy is correct. Im running a chipped p28 and also have the obd2a to obd1 jumper. I need help please !!!!!!?????????
Swamp h22 civic is offline   Reply With Quote
Old 09-19-2013, 01:28 AM   #52
Technical Hero
HondaPartsHero's Avatar
Color of spark?
HondaPartsHero is offline   Reply With Quote
Old 09-19-2013, 07:37 AM   #53
Blue. I am wondering if I might have a wire crossed on my dizzy harness would it spark if i had them wrong?
Old 09-19-2013, 12:15 PM   #54
Technical Hero
Post a pic of your wire order also
http://honda-tech.com/showthread.php?t=2919450
Old 09-20-2013, 06:52 PM   #55
I dont know how to post pics from my phone although I get my computer back Monday I can put some pictures up then. I followed the wiring diagram on the phearable.net write up in the tech help.
Old 09-20-2013, 06:59 PM   #56
Ok i will check the coil and stuff also I have a brand new coil rotor button and everything from my y7 will those work ? If not I will get the parts. Thanks for all the great information and i will check all these things and go from there.
Old 09-21-2013, 02:38 PM   #57
Ok got the car running but it will not tv over 2k. All plugs are in the right places what could cause this?
Old 09-21-2013, 02:42 PM   #58
Plugs as in sensors timing ing right spark timing is correct and I am stumped ive looked for vacuum leaks and moved sensor plugs I have tried it all. I need help pretty please.
Old 09-21-2013, 03:43 PM   #59
Technical Hero
Check engine light on?
Old 09-21-2013, 04:38 PM   #60
Yea but my scan tool wont communicate with the car
Old 09-22-2013, 04:26 AM   #61
The Tps sensor could be bad but I would have to change the throttle body to change that.
Old 09-22-2013, 06:36 AM   #62
Ok I plugged the original p2e Ecu back in it and it will rev and drive fine a little sluggish for a z6 but it drives could I need to put a different chip in the p28? Or could the p28 be a bad Ecu? Im not a shade mechanic by far but with these swaps im a little lost lol.
Old 09-22-2013, 02:15 PM   #63
Got a stock z6 Ecu and it runs like a champ thanks for all the help with everything.
Old 09-22-2013, 02:22 PM   #64
Technical Hero
:thumbs up:
Old 10-03-2013, 07:34 PM   #65
This is great. thanks for all the info!!
f155_tech is offline   Reply With Quote
Old 10-11-2013, 05:21 PM   #66
I have OB2 Everything (harness, computer, etc..)
I have a D15B Non Vtech Engine (japanese)
I have a S24A Engine
This is all in a 1997 Honda Civic HX
Having a lot of issue with the harness not matching up and shifting, rpm, cluster don't work (just RPM).
I am thinking that the harness is the issue... any help on this, would be appreciated
getmyhondaon is offline   Reply With Quote
Old 10-12-2013, 07:42 AM   #67
This is an awesome compilation>
mcraezy87 is offline   Reply With Quote
Old 10-13-2013, 03:50 PM   #68
Sorry... I meant have a S24A TRANSMISSION... NOT engine.
Old 10-13-2013, 04:33 PM   #69
Technical Hero
Are you using the stock ecu?
Old 10-14-2013, 01:45 AM   #70
Yes... using stock. And when we plug it up to get the codes for the check engine light... everything points to the transmission
Old 10-14-2013, 08:16 AM   #71
Technical Hero
Post the codes. But you'll need the correct ecu and harness adaptations for the engine either way.
Old 10-15-2013, 01:37 AM   #72
luzer91's Avatar
Very nice. But I didn't find my 93 prelude si, or any p-28's. All I see are civic&integra. 93 prelude si swapped to jdm h23a. I keep reading it's prewired green/yellow should be around pass. shock tower. I don't see it. I don't need presure. it's internal on jdm h23a right?
luzer91 is offline   Reply With Quote
Old 01-08-2014, 01:38 PM   #73
Just want to verify I'm straight on my swap please. 99 obd2a b1 into my 99 obd2b ex hatch. Its installed and just want to check the wiring. Have original harness from my car and the p75 I pulled with the motor. Am I straight? I know about lengthening the sensors and have the dizzy plug. I also have a 99 crv harness i was told will work, has anyone else heard of this? Do I need an a to b jumper? Out of state working and would like to know so I can order one if needed and can finish when I get home. Thanks
jdm400 is offline   Reply With Quote
Old 01-08-2014, 04:00 PM   #74
Technical Hero
99 CRV will be the best and easiest plug and play. You will need a B to A jumper harness as 99 CRV are OBD2B 99 P75 are OBD2A.
Old 01-08-2014, 04:55 PM   #75
Ok great, thanks for your input
* * OBD1 B-series engine into OBD2a/OBD2b civic/integra * * Katman Hybrid / Engine Swaps 657 03-11-2017 05:16 AM
Gathering EK wiring information ... Katman Hybrid / Engine Swaps 505 12-11-2016 03:41 PM
FAQ: OBD2 into OBD1 into OBD0 into vice versa (WIRING ONLY) HondaPartsHero Honda Civic / Del Sol (1992 - 2000) 9 05-28-2013 02:09 PM
FAQ: OBD2 into OBD1 into OBD0 into vice versa (WIRING ONLY) HondaPartsHero Hybrid / Engine Swaps 0 12-20-2006 07:04 PM
obd1 engine into obd2 car dizzyek Hybrid / Engine Swaps 1 02-08-2006 02:09 PM
Tags
00, 92, b18, b18c, civic, honda, housing, motor, obd1, obd2b, swap, thermostat, vtec, vx, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
