92-00 Honda Engine Swap Wiring Guide VTEC AND NON VTEC
#26
Re: 92-00 Honda Engine Swap Wiring Guide VTEC AND NON VTEC
the shocktower is what i mean if i push the wires into the shocktower it turns on but it shakes and what not while im driving so its hard to drive or get any power out of the motor and i cant find anyone who has a picture that shows me the color wire i can snip and solder to the other one so i dont have this problem anymore
#28
i have a 2000 civic obd2b with a obd2a b18b, obd2b harness and a obd2a ecu. i got a ecu jumper to make my 2b harness work with my 2a ecu would i have to still rewire the idle air control valve (IACV) from 3 wire to 2 wire even with the jumper??
#30
I'm so glad I found this! There is t any info this good in the civic Ef section! How do I go about wiring up my mini me set up. I have a 91 Si, slapping a 96 y8 head on it. Got the p28 Ecu and obd1 dizzy
#31
Technical Hero
Just wire up the vtec according to the OBD1 pinouts in this thread to the obd1 side of the adapter harness. Use a distributor adapter harness. You'll also need to wire up the 4 wire 02 according to the obd1 pinouts in this thread.
#32
Let me start out by saying that I'm new to the Honda world. Ok so I had the entire drivetrain swapped in my 2000 Honda Civic DX with an EX drivetrain and now the tachometer doesn't work. I was wondering if getting the tachometer from the EX would solve this problem. Thanks.
#34
I recently bought a 1999 Civic EX coupe someone has been under the hood not sure what's been done but the wires for the vtec valve and pressure switch go nowhere and are not in the harness going to the ECU . Any ideas
#35
Hi I'm starting my own mini me soon and was hoping for a little guidance on parts and what harness I would need I'm very new to honda and don't know a lot about engine work. I have a 1998 honda civic mb2 with a d14a8 engine. The parts I have bought for the mini me so far are, d16z6 head, d16z6 ecu and 240cc injectors. I have no idea how to wire up the vtec solanoid or if I need a harness to do this any help would be greatly appreciated.
#36
Good info, but I have a 93 hatch with the 3G zc with a p06 and someone had told me I'm running a 2 wire iacv ecu and that my engine is a three wire. I can agree with the motor being a 3 wire, as for the ecu I'm not so sure. But how can I fix this dilemma?
Additional Info:
I had the y7, and got the zc as a replacement. The zc has my y7 intake and an obd1 distributer.
Additional Info:
#37
Technical Hero
Run any manifold except the Y7 or auto Y8. You should still have the connector for the 2 wire somewhere in the bay, are you not throwing a code for IACV?
#38
I don't even know. I left my car to a mechanic and I went to take a look after I had read your thread. And ill try and see if I can get ahold of a picture, but I found a 2 wire connector but i think it was on the Intake mani so I'm sure that's not the one. And I tried looking at the intake mani that came with it but they took everything apart so I couldn't really find it. And then to top it off, the connector off the harness is broken, so I what does that mean?
Does this kinda make sense?
#40
Ok, i bought a d16y8 to replace my d16y7. I had to swap the throttle bodies in order to replace a broken tps(riveted in place) on my y8 intake manifold. I have run in to a problem in doing so. I know this thread references A three wire to two wire iacv(sp?) Swap, but this is where i have the problem. The iacv is broken off(at least the plastic part) of my y8 manifold, and it does not have the two holes needed to mount the different iacv. Also the y8 manifold does not have the holes for the rear mounted iacv to operate over. Do i have the wrong y8 intake for d16y8 with a manual transmission? Or is there an iacv that bolts to the throttle body that uses two wires?
#41
ok I have a 1996 civic took out the y7 and put in the z6 I have the obd2a to obd1 ecu jumper harness and a chipped and socketed p28. where my problem lies is the injectors plugs will not plug into the z6 Injectors even with that piece out of the clip that it shows in figure 10. and I am building a jumper harness for the z6 distributor. any help will be greatly appreciated and will help me get this thing out my yard also lol. thanks in advance for any help.
#42
Hey, Guys Im also new in the swap but my question is easy I just want to make sure im right. I have a 2000 Honda Civic SI with a 94 B18b1 ls, I bought the car and the guy that had it put a b18b1 in it. Now I have a GSR and a Type R engine will the shift linkage will fit both and will my wires be the same for both swap? Im new on this site and did not know where to post please someone help me here. Thank you
#43
The Grumpiest
#45
Technical Hero
If it fit the Los and its a stock si harness it should plug up fine. Sme as the shift linkage. There will be some minor mods to do.
#46
OK, Thank you so much HondapartsHero. Im not sure if it's the stock Harness but ill double check with the guy that I bought it from. Thank you so much again
#48
I have a 97 dx which has a non vtec harness with a obd2a gsr going into a jumper harness into a chipped p-28(obd1) ECU. Which diagram would I follow?!
