92-00 Civic - Does it Have Shocks, or Struts? I Want to Hear What YOU Have to Say.
#26
Re: (B18C5-EH2)
Yeah I remember this discussion awhile ago. In my opinion 92-95 Civics (what I have knowledge on) have struts in the front and shocks in the rear. The whole spring and shock combined makes a strut is an interesting point, but falls short when you look at a Honda parts list. I don't know... I definetely want to hear a definitive answer.
#28
Re: 92-00 Civic - Does it Have Shocks, or Struts? I Want to Hear What YOU Have to Sa
struts on a civic
shocks are whats on the rear of my tacoma (front has struts)
#29
Used interchangably among many autoparts. It happens. Yeah, there is a techincality but all in all...oh well.
#30
does it matter what they're called. if you say shock an auto shop knows what you're talking about, same thing with strut.
#31
Here's a great article for you guys.. http://www.team-integra.net/sections...?ArticleID=525
Also, I believe the newer honda cars have front macpherson struts such as the dc5, fg/fd civic while EKs, EGs, and DC2s have the double wishbone setup in the front.
#32
I think I called them shocks when I used to order from a shop. Shock or strut I always got the parts I wanted. Really that's what it comes to for me.....just make sure what I clicked on to order, is the right part when it shows up on my door step.
#35
Holy non-definitive/unsuccessful/open argument, Batman!
#36
wrong! it uses struts. just because it doesnt have the mcpherson strut suspension doesnt mean that it doesnt use struts.
a strut is a certain style of shock so you are right in that way but if you want to be technical than its referred to as a strut.
UNLESS THE SPRING CAN BE REMOVED FROM THE VEHICLE WITHOUT THE REMOVAL OF THE SHOCK ABSORBER THAN IT IS A STRUT. IF THE SHOCK AND SPRING ARE REMOVED AS ONE SINGLE UNIT THAN IT IS A STURT S-T-R-U-T!!! A STRUT IS THE COMBINATION OF THE SPRING AND SHOCK ABSORBER IN ONE UNIT. END OF DISCUSSION.
#37
1 Post
I think they're struts
why are mcpherson struts called macpherson "struts"?
the only difference is that ef,eg,and ek struts don't turn with the wheel
#38
318 Curves, 11 miles
My $.02
According to wikipedia, they're shocks. In a strut setup, the damper/spring are the main vertical structural component to the suspension, and the damper/spring assembly is known as a strut.
In a double wishbone setup like on the 92-00 civic, the knuckle is the main vertical structural component, and the damper is known as a damper or shock.
http://en.wikipedia.org/wiki/MacPherson_strut
Technically though, a damper or shock does exist in a both strut assembly and a double wishbone setup (assuming it doesn't use something crazy like torsion beams).
#39
My $.02
#40
If the vehicle uses the shock spring combo to pivot on ( when turning the wheels) its a Strut. If its just used to hole up the car its a shock. 92-00 civics use shocks. 01 and up use struts.
#41
spring - used to absorb energy
shock - dampening device used to resist motion
strut - shock + spring + some other integral part of the suspension. (balljoint, knuckle, upper a-arm, etc)
we have coilover shocks.
struts were introduced to the civic in 01.
#42
wrong. mcpherson struts rotate when the wheel is turned. the struts in 92-00 civics do not rotate when the wheel is turned. the suspension in 92-00 civics is a double wishbone strut setup not a mcpherson strut setup.
***many peoples arguments is that honda lists the part as a shock absorber, but what no one has realized is that even in the 01 and up civics which obviously have a mcpherson strut suspension the "strut" is listed as a "shock absorber unit." SO SHUT UP WITH THIS ARGUMENT. A STRUT IS A SHOCK ABSORBER! but if it has a perch for the spring to mount on then it is correctly called a strut.***
#43
1 Post
I was just saying that they're both struts in my opinion, seeing as their only difference is whether they turn with the wheel or not
#44
#45
#46
Wow, this is nuts.
The technically correct way of determining shock from strut is pretty simple.
Struts Locate Suspension components.
Shocks Dampen/control movement speed of Suspension components.
SPRINGS are a suspension component and the 92-00 Civic's springs are located where they are because of the perches which are located on the STRUTS.
End. Of. Story.
-Froth
End. Of. Story.
-Froth
DrunkPunk702
01-20-2003 09:15 PM
