Any difference between the 00 SI front crossmember and the EX?
Old 01-17-2011, 11:28 AM
TwoFaced's Avatar
Default Any difference between the 00 SI front crossmember and the EX?
Found a good deal on the subframe for an 00 si...I have an EX...i'm thinking no but is there any difference between the subframes or will this work?
Thanks in advance.
Old 01-17-2011, 11:34 AM
The Grumpiest
grumblemarc's Avatar
Default Re: Any difference between the 00 SI front crossmember and the EX?
You should check part numbers to make sure but I don't think there is any.
Old 01-17-2011, 11:35 AM
MonkeyMagic's Avatar
it'll work, they are the same part numbers.
there was some dork a few days ago swearing up and down that the si crossmember was different and beefier.. but no.
Old 01-17-2011, 11:37 AM
mechanix619's Avatar
Thanks in advance.
Are you talking about the "rear beam?" The part that the rack and pinion sits inside? If so, then they are the same for both models.
50200-S04-A02
Si:
http://www.hondaautomotiveparts.com/...gry5=REAR+BEAM
EX:
Old 01-17-2011, 12:03 PM
TwoFaced's Avatar
^ Yeah it's number 1 in that pic...thanks for the help everyone...I was having trouble finding it on majestic.
Old 01-17-2011, 12:18 PM
Master Detailer
98civdx's Avatar
Is the Si sway bar coming with it?
Best thing I ever did was put the 26mm sway bar in my car.
Old 01-17-2011, 12:37 PM
TwoFaced's Avatar
Nope I can ask how much extra it would be cause it's coming off of a parted SI...it's going to be about 110 for the subframe...what would be fair for them to add the sway bar? I would have no idea because I've never priced something like that.
How much difference is the SI bar than the EX?
Old 01-17-2011, 01:18 PM
Master Detailer
98civdx's Avatar
$110 For just the subframe? Seems like a lot to me.
I would ask them how much they want with sway bar and lca's, shock forks.
4mm difference, may not even be worth it.
When I got my si brake/suspension stuff I got everything from under the car besides sub frame and front brake lines for $250.
Old 01-17-2011, 01:23 PM
TwoFaced's Avatar
110 mainly cause it's getting shipped.
Old 01-17-2011, 01:24 PM
TwoFaced's Avatar
Scratch that it was 85 shipped.
Old 01-17-2011, 01:48 PM
Master Detailer
98civdx's Avatar
Ohh ok, that explains that.
The sway bars/LCA's and shock forks are somewhat hard to come by, I was looking for a long time before I came across mine.
if you can get everything for a fair price, I would say go for it. I would assume shipping for the subframe has got to be around $40-50.
Old 01-17-2011, 01:55 PM
TwoFaced's Avatar
49 with 35 shipping...he has other parts I need though so I'm trying to see if he will combine shipping.
Old 01-17-2011, 02:06 PM
Master Detailer
98civdx's Avatar
Oh, that isnt to bad then. I think my friend paid 50 for a new subframe. From what I seen when they come up for sale around 50 is the going the rate.
Old 01-17-2011, 02:14 PM
TwoFaced's Avatar
Yeah he has inner fender wells and the upper control arm I need. All this plus a new si rim and lip and Ill be fully recovered.
Old 01-17-2011, 02:26 PM
Master Detailer
98civdx's Avatar
I need a inner fender well too lol
Old 01-17-2011, 03:00 PM
TwoFaced's Avatar
PatrickFrantz
05-12-2009 10:37 AM
FBP EM1
10-13-2007 09:44 AM
wudini
03-01-2007 12:39 PM
civicsib16b
02-16-2004 01:07 PM
Quick Reply: Any difference between the 00 SI front crossmember and the EX?
