50A Ignition Fuse Blowout
Re: 50A Ignition Fuse Blowout
Sounds like your power wire is grounding against something. Make sure your connection at the terminal is solid, there isn't any corrosion around the terminals, and run the length of positive and negative wires with your fingers to make sure they aren't damaged.
