4x100 to 4x114.3 Lug Conversion question!!
Old 04-11-2004, 04:57 PM
ozzyman's Avatar
Default 4x100 to 4x114.3 Lug Conversion question!!
Okay, I've been searching for a half hour now and can't find what I'm looking for.
I know you can get the 96-97 spec ITR suspension to convert DC/EG's to 4x114.3. I also heard that there is another way to do it to get the 4x114.3. Something about Accord or Prelude hubs and all you do is bolt them on?? I'm not exactly sure what to look for and how it works. If anyone has any input, please share. TIA.
Old 04-11-2004, 05:04 PM
Darth ModerVader
Padawan's Avatar
Default Re: 4x100 to 4x114.3 Lug Conversion question!! (ozzyman)
Out of curiosity, what is your motivation for wanting to perform the conversion?
Old 04-11-2004, 05:07 PM
B_CRUZ!'s Avatar
Default Re: 4x100 to 4x114.3 Lug Conversion question!! (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Out of curiosity, what is your motivation for wanting to perform the conversion? </TD></TR></TABLE>
Old 04-11-2004, 05:08 PM
ozzyman's Avatar
I have 4x114.3 Mugen M7's that I desperately want to put on. Also like the styling of the 96 ITR wheels and want to do something different.
Old 04-11-2004, 05:16 PM
Ricey McRicerton's Avatar
I just did a writeup on the 4x114.3 onto a Civic using the ITR stuff. If you want, you can look through the 96 ITR Brake thread and see what parts are interchangeable, and you could "custom make" some 4x114.3 brakes.
Old 04-11-2004, 05:28 PM
slammed_93_hatch's Avatar
Default Re: 4x100 to 4x114.3 Lug Conversion question!! (Ricey McRicerton)
to convert it to the the 4x114.3, is to use the hubs from a prelude's. thats all you really need.
you can use any brake setup off of a 4x114.3 hub you want
Old 04-11-2004, 05:49 PM
ozzyman's Avatar
Default Re: 4x100 to 4x114.3 Lug Conversion question!! (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">to convert it to the the 4x114.3, is to use the hubs from a prelude's. thats all you really need.
you can use any brake setup off of a 4x114.3 hub you want</TD></TR></TABLE>
What year and model Prelude??
Old 04-11-2004, 06:04 PM
ozzyman's Avatar
TTT
Old 04-11-2004, 07:41 PM
92-96, or any other car that came with 4x114.3
Old 04-11-2004, 07:45 PM
and as far as model well the hubs are all the same the brakes are what are different. the only thing i know is the the vtec moddle has 11.1" rotors
Old 04-11-2004, 07:55 PM
. o 69 o .'s Avatar
its easier and most likely cheaper just to buy a JDM ITR 4 x 114 conversion. I would not do it again if given the choice
Old 04-11-2004, 08:44 PM
ozzyman's Avatar
Default Re: 4x100 to 4x114.3 Lug Conversion question!! (B16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B &raquo;</TD></TR><TR><TD CLASS="quote">its easier and most likely cheaper just to buy a JDM ITR 4 x 114 conversion. I would not do it again if given the choice</TD></TR></TABLE>
Want to trade???
Old 04-11-2004, 08:49 PM
Filliam H. Muffman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">and as far as model well the hubs are all the same the brakes are what are different. the only thing i know is the the vtec moddle has 11.1" rotors</TD></TR></TABLE>
I like how you spell model.
yeah, accord and 3g prelude have that bolt pattern, but im not sure it will work from a prelude.
Old 04-11-2004, 08:51 PM
92b16vx's Avatar
Also I believe the brake caliper sit a little further out, on mine, I have the ITRs (96 rim), and the brake are from a Aerodeck (I have to check to see if the parts numbers are the same as the Prelude) But the ITR contacts the caliper, I had to run 3mm spacers. But anyway, once I can get my lazy *** to Honda and cross the parts numbers I'll know for sure. And they are the same as one of the model Accords too, which should be easy and cheap to find in a junkyard.
Old 04-11-2004, 09:17 PM
Default Re: 4x100 to 4x114.3 Lug Conversion question!! (92b16vx)
that has been the case from day one in the (FAQ 95.5-97 ITR brake thread) the calipers them sleves are bigger, i just ground down the caliper alil and all was well. and im willing to say that they are, im 99% sure they are becuase every other car that came with the 11.1" rotor in the same spec's as the ITR all have the same caliper.
and the wheels from the 96 ITR were just not made to be able to handle that big of a caliper. from what i have heard most after market wheels will fit without modification ( if they fit on a prelude vtec they will fit on a 96 itr setup)
flatblackfury91
18
06-20-2008 09:46 AM
plalude1
10-14-2007 07:24 PM
alain401
08-28-2007 06:34 PM
Jdm_honda_ek9
43
08-02-2005 03:02 AM
guywitaDA
07-13-2005 06:29 PM
Quick Reply: 4x100 to 4x114.3 Lug Conversion question!!
