vtec head or bigger cams and turbo?
Old 11-05-2007, 03:19 PM
pigpen56pb18's Avatar
Default vtec head or bigger cams and turbo?
I got a 1995 hond civic ex with a b18b motor swap and i was wandering if i should get a vtec head or just buy bigger cams , cam gears and vouls and then possible turbo please tell me witch would help me be faster off the line and just on a quarter mile.
Old 11-05-2007, 03:22 PM
posHonda's Avatar
What you SHOULD get??? What you should get is what you want and not doing what HT wants for you.
A vtec head flows much better than an LS head, but youre going to have to know how to do an ls/vtec build properly. Whats your budget and how much power are you looking to make?
Old 11-05-2007, 09:36 PM
Late Riser's Avatar
Default Re: vtec head or bigger cams and turbo? (pigpen56pb18)
If your asking a question like that, you might want to start slow and do lots of research.
Both of your options require a fair amount of work and money, unless you do all the work yourself. Out of the two I would suggest the ls/vtec to start out with. The head, im, oil feed kit, arp studs and bolts, to name a few, would put you in the ballpark of $1000.
Most good turbo setups would be about $1500-3000 between the hardware and tuning.
Its always best to just take your time and learn as much as you can along the way.
Old 11-06-2007, 03:45 PM
Default Re: vtec head or bigger cams and turbo? (Late Riser)
my budget is around a 1500 dollar but i have a job so the money is flowen but what ive heard it if i get crower cams and cam gears ill have better flow then a vtec also if i buy a voul then i would even sping out like a vtec
93h2beg
11-22-2016 10:53 AM
93' smurf integra
08-20-2007 06:26 PM
b18itr5lug
07-08-2005 12:42 AM
willahlborn
09-29-2004 05:30 PM
moondoggieoo7
01-14-2004 05:00 AM
Quick Reply: vtec head or bigger cams and turbo?
