2000 honda civic si with no spark?
Old 03-27-2014, 06:24 PM
dragonkx's Avatar
Default 2000 honda civic si with no spark?
My civic just died this week, It looks like theres no spark. I used a spark tester and no spark. but to be sure I removed two spark plugs from the engine, and turned on the engine while its still connected to the spark plug wire and nothing. I warranted the distributor and still nothing. The spark plugs do have some corrosion on the tip, but doubt both of them could die at the same time. Any ideas on what the problem could be. Spark plug, spark plug wire, ECU, other electrical wire???
Old 03-27-2014, 06:39 PM
Former User's Avatar
Default Re: 2000 honda civic si with no spark?
CEL codes?
Does the fuel pump prime?
Old 03-27-2014, 06:54 PM
dragonkx's Avatar
lol, before trying all this other stuff, I forgot to check the code. Its P1359, CKP/TDC sensor connector disconnection. Hopefully I can fix it.
Old 03-28-2014, 09:20 AM
rovafa2002's Avatar
I think you will have to remove the CrankShaft Pulley and the Distribution cover to get access to this sensor.
If that's so, you will need an special tool in order to remove the crankshaft pulley.
Old 03-28-2014, 09:51 AM
The sensors are inside the distributor.
Old 03-28-2014, 10:58 AM
rovafa2002's Avatar
My bad I thought he meant Crankshaft position sensor
Old 03-28-2014, 11:36 AM
I think you actually meant the CKF sensor.
Old 04-04-2014, 02:40 PM
dragonkx's Avatar
No it is the sensor where the crankshaft pully. at least that's what the code gave me. I mean if it was a sensor inside the distributor then its not the problem. For one, I just warranteed by distributor with a brand new one after it died and still wouldn't start. Seems like a lot of work, so im just holding off till I get the part
Old 05-17-2014, 11:44 PM
dragonkx's Avatar
Well it turns out, It wasn't the sensor, but something else was tripping the code for the sensor. My timing belt broke. Required a lot more work, but it was changed and works fine now
crazyguy
08-19-2007 07:57 AM
GoldCoin
08-21-2006 06:29 PM
Rex18c
11
01-09-2006 07:46 PM
trianglegreg
10-26-2005 06:18 PM
keithv
10
03-06-2003 06:28 PM
Quick Reply: 2000 honda civic si with no spark?
