2000 civic transmission rebuild with ATF feed pipe screen
Old 01-08-2016, 12:52 PM
shiguiy's Avatar
Default 2000 civic transmission rebuild with ATF feed pipe screen
right now I am rebuilding the transmission b4ra and I notice one ATF feed pipe with screen on the end. just wonder this screen end should face up or down and which valve it should go to. I know it has to be on main valve or secondary valve. the item on the diagram for both valves is #1 on hodna estore and both have the same catalog number. thanks
Old 01-08-2016, 12:54 PM
Former User's Avatar
Default Re: 2000 civic transmission rebuild with ATF feed pipe screen
Did you check in the service manual?
Old 01-08-2016, 01:32 PM
shiguiy's Avatar
can not see that from service manual. none of them has been marked.
BrakeExpert
Suspension & Brakes
66
02-13-2017 06:33 PM
Rhood
01-19-2007 05:52 PM
BrandonClaps
05-13-2005 10:05 AM
Teg44
06-19-2001 11:17 AM
Quick Reply: 2000 civic transmission rebuild with ATF feed pipe screen
