2000 Civic Si RPM too high?
Old 08-23-2004, 06:15 PM
FBP EM1's Avatar
Default 2000 Civic Si RPM too high?
When I'm driving on the freeway at about 80mph my RPM is running about 4500, is this normal? My car is bone stock with no mods whatsoever.
Thanks
Old 08-23-2004, 06:17 PM
hayabusa160's Avatar
Default Re: 2000 Civic Si RPM too high? (deltree)
thats about right the stock tac is off a bit sometimes too mines off by 500 sometimes
Old 08-23-2004, 06:38 PM
Go Tigers!
Bense's Avatar
i can completely relate to your thinking. Because a few months ago i was thinking exactly what you're thinking. I even thought about getting a integra LS 5th gear because the RPMs were so high.
Here's a quick lesson that will help you understand it.....
each RPM your pistons are moved all the way up and all the way down. the b16 has a very short stroke of 77mm so each rpm the pistons go down 77mm and back up 77mm. So that means that they move a total of 154mm each rpm. The b18b/b18a has a stroke of 89mm so each rpm the pistons are moved 178mm
so let's say that when your crusing at 4500rpms that's 4500 x 154 = 693,000
now lets take that number that we get when we multiply RPM x STROKE x 2
so 693,000 divided by 178mm (from the 2 times the b18b/a stroke of 89)
693,000 / 178 = 3893.2584 RPMs
so your b16a's 4500rpms is equivalent to an integra LS crusing at 3893.2584 RPMs
So there you go. Yes your cranking out the high rpms, but your motors pistons move significantly less each RPM than your average motor.
hope this helps.
Modified by thebense at 1:27 PM 8/24/2004
Old 08-24-2004, 12:10 AM
Gerbilo's Avatar
Default Re: 2000 Civic Si RPM too high? (thebense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thebense &raquo;</TD></TR><TR><TD CLASS="quote">hope this helps. </TD></TR></TABLE>
you're insane... mad scientist!
but yeah, at 80mph i'm at 4k in my GS-R... I thought that was insane after coming from my old civic or being in any of my friends cars that don't rev to 8k lol...
then my friend was sayin about his B16/tranny... just like yours... it's normal
Old 08-24-2004, 12:31 AM
handa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thebense &raquo;</TD></TR><TR><TD CLASS="quote">i can completely relate to your thinking. Because a few months ago i was thinking exactly what you're thinking. I even thought about getting a integra LS 5th gear because the RPMs were so high.
something new learned today
yeah i had the same question about a week ago: https://honda-tech.com/zerothread?id=961792
after going 80mph @ 4.5k rpm i just get used to it.
Old 08-24-2004, 01:14 AM
eL
eL's Avatar
I too wish my 5th gear wasnt so short.
Old 08-24-2004, 05:37 AM
All Motor Mentor
00Red_SiR's Avatar
Your engine revs that high because the transmission was designed to keep the engine near it's optimal power range. B16's make no torque and are designed to rev (short stroke) so they have to rev to really move. Put an LS transmission in a GSR, you'll rev less, get better gas mileage but the car will accelerate slower because the gears aren't optimized for that engines power curve. Everytime you shift, the car will drop out of VTEC and unless you keep it in VTEC it wil be SLOW.
Old 08-24-2004, 10:40 AM
Gerbilo's Avatar
Default Re: 2000 Civic Si RPM too high? (00Red_SiR)
exactly! if you want good mileage go buy an HX!!
Old 08-24-2004, 10:44 AM
-Trinitron-'s Avatar
I hit VTEC in 5th at 100...an LS 5th would be such a drop in rpm though. Si's should be 6 speed!
theg35show
03-11-2009 11:45 AM
thunderboy
01-03-2009 11:25 AM
Mfoehrkolb
42
07-23-2008 07:11 PM
93CharcoalHatch
08-23-2005 03:09 PM
MugenizedR
10-29-2003 08:27 PM
Quick Reply: 2000 Civic Si RPM too high?
