2000 civic si no start
#26
Main relay ticks when trying to start
Hi i have a 2000 Honda civic Ex with a Si swap. When i try to start it the main relay just ticks and the motor doesn't crank. At first it used to tick only after the motor was hot but now it wont turn over at all. I got a new main relay and its still doing it. The fuse is good too. Any ideas?
#29
Re: Main relay ticks when trying to start
Grounds are good. I cleaned them and tightened them and still wont crank. Main relay isnt ticking. It clicks and you can hear it wants to start. Im thinking bad starter?
#31
So i had jumped the starter and got it running and drove it around for 20 minutes and when i got home i decided to humor myself and try to start it just to see and now it cranks and starts...
#32
Good that it's starting, but if the problem returns check your neutral safety switch. I replaced my starter thinking it was bad but in reality the switch was the culprit. I had similar symptoms and the problem was also intermittent just like yours.
#34
2000 honda civic si no crank
Hi i have a 2000 Honda civic si manual trans. Wont crank. Will push start or i can start it by jumping the Positive wire on the starter to the signal wire. Starter is new. Took my old one in today and got it tested. Failed so i bought a new one. I have a ground directly onto the starter and my number 9 and 31 fuses are good. Replaced my main relay a few months back with a used one too. Any ideas would be appreciated thanks!
#38
#39
Re: 2000 honda civic si no crank
#40
That looks like the lower cruise control stopper. The starter switch stopper is at TOP of the clutch pedal.
Messing with wires that you don't understand could cause your car to go up in flames or worse. Return your wiring to stock, and consult somebody with electircal knowledge.
#44
Keep studying the pedal anatomy. Each stopper has a corresponding switch. Do you see both switches? Find the switch, find the rubber stopper or the hole where it inserts.
#47
#49
