2000 civic si in car fuse box diagram, or tell me where this fuse is.... - Honda-Tech
Old 10-02-2003, 09:39 AM   #1
staticchmbr's Avatar
Default 2000 civic si in car fuse box diagram, or tell me where this fuse is....
on my 2000 civic si, the passenger head light blew out on the low beams. i changed the bulb, checked the wires, and it still doesnt work. i need to know where that fuse is, because thats the only thing left that i can think of. i cant find the panel cover with the diagram. i also checked the search over and over. please give a pic of the diagram, or tell me where that fuse is.
staticchmbr is offline   Reply With Quote
Old 10-02-2003, 09:51 AM   #2
Charlie Moua's Avatar
Default Re: 2000 civic si in car fuse box diagram, or tell me where this fuse is.... (staticchmbr)
WELL pull one buy one and check....if you don't have the diagram... should not take more than 3 mins
Charlie Moua is offline   Reply With Quote
Old 10-02-2003, 10:20 AM   #3
Phastnphun's Avatar
Default Re: 2000 civic si in car fuse box diagram, or tell me where this fuse is.... (Charlie Moua)
Out by the battery there is a fuse box. Its like a 30amp fuse I think? and if I rember right its the one in the center?
Phastnphun is offline   Reply With Quote
Old 10-02-2003, 11:05 AM   #4
i guess i could just try all the fuses, but there are like 20 of them under there. i will also check the one under the hood, but i dont think its there. wont hurt to check. anyone else have input?
Old 10-02-2003, 11:22 AM   #5
sil
sil's Avatar
Quote:
it's not by the battery.. and i'm pretty sure it's a 10amp fuse.. i don't remember which one it is.. but i've basically narrowed it down some more for you..
sil is offline   Reply With Quote
Old 10-02-2003, 11:42 AM   #6
PupaScoopa's Avatar
Default Re: 2000 civic si in car fuse box diagram, or tell me where this fuse is.... (sil)
Middle row, far right two fuses are for the low beams. The low beams are on a different circuit than the high beams, so your highs should be working right now. If they don't it may be a problem with the harness.
PupaScoopa is offline   Reply With Quote
Old 10-02-2003, 11:57 AM   #7
jerseybrandon's Avatar
High/Low Left/Right all independent fuses???
Might want to look elsewhere.
jerseybrandon is offline   Reply With Quote
Old 10-02-2003, 01:34 PM   #8
civickidd99's Avatar
Default Re: (jerseybrandon)
pupascoopa got it, check highs and go from there
civickidd99 is offline   Reply With Quote
2000 Civic SI cigarette lighter fuse? em1xiong Tech / Misc 0 12-15-2014 12:20 PM
Honda Logo Fuse Box Diagram SOHCunderdog Tech / Misc 6 10-09-2010 08:19 AM
fuse panel diagram??? 94civicspeed Honda Civic / Del Sol (1992 - 2000) 0 04-12-2005 02:55 PM
Keep blowing fuse, looking for advice CaptainGSR Honda CRX / EF Civic (1988 - 1991) 22 07-09-2004 08:03 PM
Need EG fuse diagram, ASAP! HELP!! _jester_ Honda Civic / Del Sol (1992 - 2000) 4 01-11-2004 05:41 PM
Tags
00, 15, 2000, box, circuit, civic, diagram, fuse, headlight, honda, panel, problem, radio, si, size
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
