jdm 5 lug with d series axle?
Old 09-21-2003, 01:23 AM
an2ny888's Avatar
Default jdm 5 lug with d series axle?
Anyone know if this is possible? i know my d series axle is 32 mm while the jdm 5 lug usues a 36 mm shaft. can i use an outer cv joint from any other honda model ( accord, prelude,etc) to make this work?
Old 10-02-2003, 12:29 PM
vizeta's Avatar
Default Re: jdm 5 lug with d series axle? (an2ny888)
looking for the same answer. bump for u.
Old 10-02-2003, 12:34 PM
dampachi's Avatar
i also wanna find out because i heard that the braking power is so much better with 5 lug
Old 10-02-2003, 12:36 PM
2000blackgsr's Avatar
Default Re: jdm 5 lug with d series axle? (dampachi)
https://honda-tech.com/zerothread?id=452305
Old 10-02-2003, 12:38 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know if this is possible? i know my d series axle is 32 mm while the jdm 5 lug usues a 36 mm shaft. can i use an outer cv joint from any other honda model ( accord, prelude,etc) to make this work?</TD></TR></TABLE>
No, you cannot. Unless you get custom axles for your D series with 36 mm outer CV ends, they will not be compatible.
I would recommend getting US ITR 5 lug or JDM CTR 5 lug hub/knuckles being they are 32mm, and they will go right onto your stock D series axles.
Old 10-02-2003, 12:40 PM
tonyxcom's Avatar
Default Re: jdm 5 lug with d series axle? (poison)
I think for the long run, if you can only find a JDM 5-lug...
Instead of getting custom axles made or frankensteined, just spend a little more money now and get a USDM hub and replace the JDM one. That way you can use standard axles and when your axles go bad, you can still use the pepboys crap.
The hubs are about 140 each online, but you will ruin the bearings pressing the hubs out so new bearings are gonna be 50-70 each as well.
Old 10-02-2003, 12:43 PM
Nextelbuddy's Avatar
Default Re: jdm 5 lug with d series axle? (tonyXcom)
i underastand why people want this setup but why before a swap?? that boggles me. what good is that increased braking and mad tyte stunna 5 lug if you dont have the power to back it up. im just curious
Ekstan
Suspension & Brakes
03-05-2019 08:56 AM
Mr. Tech
23
08-17-2006 10:59 AM
For Hybrids
10-06-2003 05:34 AM
Quick Reply: jdm 5 lug with d series axle?
