2000 Civic Si; Lift point help
So this will probably sound dumb to those who read this. For Christmas, I received a floor jack, creeper and jack stands because i wanted to work on the cars in my home. Well, since it finally started warming up, I figured I should start looking into good locations to jack up my car.
I drive a 2000 Civic SI. I've visited other forums and some of have said there is a lift point right in the middle near the front where I can jack it up. I'm familiar with the side lift points but when I want to do an oil change, I feel that doing the one side and then the other will put to much stress on the car.
So is there actually a spot in the front middle area to lift it up? What's your opinion about this? Which option/way should i do it?
Also, if you have a picture of the front lift point (if there is one), could you post it? I prefer visuals instead of hunting for it.
I have lifted my car before but with a hydraulic lift at my school, however when I graduated, I could not use it anymore so now I'm left with this. Hope some can help me, thanks guys!
Re: 2000 Civic Si; Lift point help
Would anyone suggest the side-side method? (lift one side and then move to the other)
Someone mentioned that like the sides, where there is an arrow pointing to the lift point that there is one near the front end. Could it be under the splash guard and do you think I should get rid of that guard?
Theres a lift point on the front if your car, Its probably silver. Its not directly in the middle, kinda on the drivers side more. its about 4 inches wide and an inch deep. I use that and then put jack stands under the life points on the side of the car.
Id never use the oil pan, lol
I use the radiator support frame in the front and stick the jack right there and lift it high enough to put jackstands on both side of the car.
Cool Cool Island Breezes. BOY-EE
This is my lifting procedure: I have a big, low profile jack with a 5'' round pad. So it's a large pad...not a really small pad like a small jack would have.
I pick a place on the side rail. It does not have to be the designated lip lift point. Anywhere on the pinch rail will do. Meaning anywhere between the 2 lip lift points along the sideskirt will do.
I lift from there. I put the jackstand underneath the lip lift point. Done. Then move onto the other side.
Some people use the oil pan to jack it up (not recommended). Some use the factory tow hooks at the front. The only place I can think of is the subframe just behind the engine, but that seems waaay too far back to reach with a floor jack. Unless you find a sweet spot on one of the suspension components up front, I think you may be out of luck.
The subframe behind the engine? Way too far in. The trans housing and header would get in the way.
Suspension components? This car has an independent suspension. Meaning that those can move and make the jack slip. You have to get to a flat spot on the LCA. Difficult.
You can jack up a car anywhere along it's pinch rail if you have a big enough pad. Use a jack with a large pad...then use my method that I described above. I've been using it for 7 years. Flawlessly.
Nobody uses the oil pan.
1 Post
nobody lifts up the car on the oil pan. who ever does is an idiot.
oil pan and control arms are a no no.
i dont recommend lifting by the front tow hook. you can bend the tow hook with all that weight. also no balance.
i also dont recommend lifting one side at a time. its do-able, but while lifting the second side, youre rocking the car...not stable. the jacks can fall over. not safe.
use the front radiator support frame. cant go wrong with that. follow ifIexplodes directions.
mk, just to clear up things.
The best location to lift the car is from the support frame under the radiator correct? Anyone have any pictures of that just to help me out by pinpointing it?
The reason why I ask this question is because i saw a guy doin a video of this procedure and he lifted one side and then the other. This is greatly appreciated.
YodaIsGod
08-27-2002 05:40 PM
