2000 civic heat problem ?
Old 03-17-2003, 04:46 PM
fsarfino's Avatar
Default 2000 civic heat problem ?
Posting this for a friend
Problem: Heat is working but does not get very hot
Things we tried : Checked all fuses that are related to heat system, Checked coolent level it was topped off, Fan is working fine.
What I think it is : Heater core
This car only has 60,000 miles on it thats why I was not very sure on recomending that the heater core might be bad.
Old 03-17-2003, 05:15 PM
97hb's Avatar
Default Re: 2000 civic heat problem ? (fsarfino)
Could be the t-stat not opening properly. Could be the cable that opens the valve for the antifreeze to enter the heater core is stuck. What about the temp gauge on the dash? Is it normal?
Old 03-20-2003, 05:32 PM
fsarfino's Avatar
Default Re: 2000 civic heat problem ? (97hb)
Sorry forgot to mention that the themostat was replaced and the temp needle on the dash reads normal temp
Old 03-20-2003, 05:34 PM
black92si's Avatar
check the cable on the heater valve. that sometimes can get stuck. what is the temperature of the air coming out of the vents? should be at a max of 92 degrees or something.
Old 03-22-2003, 06:42 AM
fsarfino's Avatar
Default Re: 2000 civic heat problem ? (black92si)
thanks I'll tell him to have a look at it
EG94dude
11-26-2009 07:39 AM
Homotor
11-20-2009 06:00 AM
love4cars
12-27-2004 05:11 PM
94_CRVtec
10-29-2004 02:06 PM
Cosworth
05-10-2002 10:04 AM
Quick Reply: 2000 civic heat problem ?
