2000 Civic EX catalyst in CA.
At 233k miles, she runs great but, is now asking for a new catalytic converter per the check engine light.
Dealer says it's a federal car with only a single catalyst at about the center of the car (I see it bolted on at both ends along the exhaust pipe). OEM is about 1k ($670 @ magauto) and a local muffler shop said they could have an aftermarket installed for about $400.
What do you think?
I've heard the aftermarkets last only a year or two and even though the OEM comes with a 12m/12k warranty, they last much longer. This ride already had 192k when I got it so I don't know if it's the original. My guess is that it is. And if so, the OEM price is plenty with it.
Thanks for any insight.
What do you think?
Re: 2000 Civic EX catalyst in CA.
What do you think?
What do you think?
I've personally been using an aftermarket Magnaflow direct bolt on cat (california legal) for about 6years with no issues at all on my ej1. they're about $400 on eBay i think, the part # is 448630. i would install that, and not clear your check engine light, so your pcm doesn't have to set all of the other readiness monitors that you have for your other emissions systems all over again. After the pcm sees the right driving conditions to run the catalyst monitor, it will run it, see the correct pre and post cat o2 sensor fluctuation, and clear the code itself, and it will be ready to pass a smog inspection. hope i helped
Awesome! Never thought about eBay. Thanks for that and suggesting I let the system clear itself, great idea! I'll do just that. Shopping for that cat continues.
EDIT: I did this on my cellphone thats why the spelling is so messed up. I
hey so i took of my old cat today. its in good condition. i thought it was bad but it was a plugged muffler. I just passed 3 months ago. one stud broke off the flange that can be taken out and use another bolt, if you want it pay for the shipping and fling me 20 and its yours. from a 2000 ex coupe also im in CA 92251 look that up and find the cheapest shipper ill take some pics to show you
It wasn't the cat. It was a plugged muffler. Thats why I was weirded out because I just passed smog with flying colors a few months ago. So yes the cat is in good condition. You can look thru it and is not plugged at all. It'll work good for smogging your car. But like I said. You stud needs to be heated up and hit out then it could be tightened down with another bolt. The other two studs are good, I put their bolts back on also so they won't be lost. If you want it let me know. Or else I'll just put it in my garage and hold onto it.
Here's the thing, sorry if it's a long story. I started with random stalling, once or twice a day with no cell. One Sun it stalled 10 times and in looking into it deeper I found an SB that spoke about defective ignition switch. Being a Sun, no dealer was open. Thinking it was the electrical contacts, I got an after market harness from Riebe's. Well, crap, it brought on even more issues, AND lit up the cel for a cat.
Longer story short, I put my original harness back in, changed the distributor with one from the wrecking yard (that fixed the stalling), and cleared my cel. First, with disconnecting the batt, it came right back. Second, with a hand held reader, it came back within 30 miles. Third, with a diagnostic tool at a smog shop, 80+ miles now and the cel is still OFF.
Yahoo.... Please hold on to it for me for just a bit.
Well crap ola, it's on again. Like before, it's a P0420. Thanks a bunch for the offer, I sent you a pm.
Well, that cat I got from 710times was trash. I ended up paying a muffler shop to install an aftermarket for $175 plus $100 labor.
turq93t
22
06-08-2006 03:17 PM
