2000 civic DX check engine light code
Old 04-28-2009, 04:54 PM
h22egAZ's Avatar
Default 2000 civic DX check engine light code
my check light is on is there anyway i can check the code out on my self....
also cant u just put a safty pin in sumwhere
Old 04-28-2009, 05:01 PM
Former User's Avatar
Default Re: 2000 civic DX check engine light code
Click here.
Old 04-28-2009, 07:50 PM
h22egAZ's Avatar
Originally Posted by RonJ@HT
Click here.
thanks
Old 04-28-2009, 07:52 PM
h22egAZ's Avatar
throwing code P0420, P1457
can anyone help me out on these codes
Old 04-28-2009, 08:12 PM
DBG0823's Avatar
P0420 Catalyst System Efficiency Below Threshold
P1457 Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System)
top of tread there is a post of codes.
but i checked for you.
b-town bump
Old 04-28-2009, 08:20 PM
P0420 -- probably a bad cat, but also look for an exhaust leak.
P1457 -- start by checking whether the seal on the gas cap is bad.
Old 04-28-2009, 08:26 PM
DBG0823's Avatar
listen to RonJ@HT
he help me out with problem i had and worked great.
Old 04-28-2009, 08:55 PM
Arthas's Avatar
A very common late 90's code, P1457 is a failure in one of the evap system solenoid valves. There are 2 culprits, the Vent Control Valve & the 2 Way Bypass Valve. They are located under the vehicle, roughly below the left rear seat area. They short out due to corrosion/contamination from water seeping into the valves. I changed both, but the real culprit seems to be the 2 Way bypass Valve.
velonorton1974
Honda Civic (2001 - 2005)
10-27-2009 03:27 PM
XrainmanX
08-29-2009 02:37 PM
LoGaN-VanG
07-01-2009 08:18 PM
Eddie99
Honda S2000
11-07-2007 09:31 PM
jeremy8886
12-07-2005 06:54 PM
Quick Reply: 2000 civic DX check engine light code
