2 Codes after Going boost
I have also posted this in the Forced Induction forum, cause i really need an answer
3 MAP - manifold absolute pressure sensor
8 TDC - top dead centre sensor
Got these two codes after going boost. Dnt know why. I know that code 8 is in the dizzy, but what i dnt know is how to fix them. Did the sensors go bad or is it cause of the boost? Car is a 95 honda civic ex with a d16z6 in it if that helps
Modified by sohcvtec1995 at 4:02 AM 1/29/2005
Re: 2 Codes after Going boost (Revolver)
im geussing you dont have a missing link, if you dont thats why you are geting that Map code , but the top dead center code i dont know , the sensor is in the dizzy, so try a buddys dizzy and get a missing link
Re: 2 Codes after Going boost (kKdARIAN)
Its a z6 with 450cc dsm's. Running the afc hack. Dnt have any check valves, or a missing link. But today i drive the car and it has no cell's and is running fine. Still got some smoke coming out the back but other than that it seems fine. Me and Slammed Sol played witht he timing and the fuel it is seems ok for now. Also we were trying to do a uberdata chip and for some reason my ecu is not likeing it. I have a p28 ao2 and he has a p28 aoo. Is there a difference?
Re: 2 Codes after Going boost (vtec69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 »</TD></TR><TR><TD CLASS="quote">how much boost you running?</TD></TR></TABLE>
7psi, nothing big.
7psi, nothing big.
elpiar
03-22-2005 06:02 PM
