1999 HONDA CIVIC EX STARTER RELAY LOCATION
Old 11-02-2011, 02:48 PM
.b20coupe.'s Avatar
Default 1999 HONDA CIVIC EX STARTER RELAY LOCATION
I was wondering does anyone know where the starter relay is for a 1999 Honda Civic Ex?
.b20coupe. is offline
Old 11-02-2011, 03:38 PM
Former User's Avatar
Default Re: 1999 HONDA CIVIC EX STARTER RELAY LOCATION
Just curious why you need to know. It's very rare for that relay to go bad.
Former User is offline
Old 11-02-2011, 03:43 PM
.b20coupe.'s Avatar
I'm having trouble getting my car to start. Starter and battery are both good, but car doesn't crank to start. any suggestions?
Old 11-02-2011, 03:45 PM
The red arrow points to a rubber stopper at the top of the clutch pedal. Has it fallen out?
Old 11-02-2011, 03:52 PM
.b20coupe.'s Avatar
No, its still there..
Old 11-02-2011, 03:56 PM
With the key in START/ON(III) and the clutch pedal depressed, do you measure battery voltage at the starter solenoid terminal?
Old 11-02-2011, 04:03 PM
.b20coupe.'s Avatar
how do i do that?
Old 11-02-2011, 04:13 PM
Do you have a test light or multimeter and a helper buddy?
Old 11-02-2011, 04:24 PM
.b20coupe.'s Avatar
i have a test light
Old 11-02-2011, 04:29 PM
Have a buddy hold the key in ON(III) and the clutch pedal down, while you test for voltage at the Blk/Wht wire terminal of the starter solenoid. This is done by touching one test light probe the starter solenoid terminal and the other test light probe to the thermostat housing or some other metal part of the engine or transmission. Does the test light turn on?
Old 11-02-2011, 04:34 PM
.b20coupe.'s Avatar
do i leave the terminal connected to the starter or disconnect it?
Leaving it connected is fine.
Old 11-02-2011, 04:36 PM
.b20coupe.'s Avatar
i have a multimeter as well..would it be better if i tested it with that?
Old 11-02-2011, 04:43 PM
Yes. Same test with multimeter set to read DC volts on the 20V scale. Red probe to solenoid terminal and black probe to ground as I mentioned earlier.
Old 11-02-2011, 05:19 PM
.b20coupe.'s Avatar
the voltage it gave me was 12.20v
Old 11-02-2011, 05:33 PM
With the key off, now measure voltage at the large black starter motor wire. Red probe to starter terminal where the black wire is connected; black probe to the engine or transmission.
Old 11-02-2011, 05:40 PM
.b20coupe.'s Avatar
12.72v
Old 11-02-2011, 05:44 PM
Set the multimeter to measure resistance (Ohms) on the lowest scale. Touch one probe to the transmission housing and the other to the negative (black) battery post. What is the Ohm reading?
Are you able to push start the car?
Old 11-02-2011, 05:55 PM
.b20coupe.'s Avatar
not sure if i did it right, but its at .001
Old 11-02-2011, 05:59 PM
.b20coupe.'s Avatar
not sure about pushing starting it, but i can start it by jumping the large black ground wire to the positive ignition wire..
Old 11-02-2011, 06:00 PM
What Ohm scale is the multimeter set on? Or is it auto ranging? What Ohm reading do you get when touching the two meter probes together?
Old 11-02-2011, 06:03 PM
.b20coupe.'s Avatar
0.000
Old 11-02-2011, 07:57 PM
You are not answering all questions, so it's hard to help you. So far the results seem to point to a bad starter, though you definitely want to give more details about this:
...but i can start it by jumping the large black ground wire to the positive ignition wire..
Old 11-03-2011, 11:41 AM
.b20coupe.'s Avatar
I had took my starter to Autozone to get it tested and it was good..
Old 03-05-2016, 11:12 AM
Matt Petty's Avatar
You ever fix this problem? I'm having the same issue I think it may be the starter relay
Matt Petty is offline
Quick Reply: 1999 HONDA CIVIC EX STARTER RELAY LOCATION
