1999 Honda Civic check engine light blinking! - Honda-Tech
Old 12-05-2008, 10:36 AM   #1
Default 1999 Honda Civic check engine light blinking!
I started it this morning getting off work and the check engine light started blinking. It has come on once before and just stayed on solid because of the o2 sensor needing to be replaced. Now it comes on and blinks off and on. It also has trouble picking up speed and feels like front end is jumping?
Feels like i have lost compression is hard to pick up and go. The car is slugish and feels like it has no power and can barely go. There is also a clicking sound that clicks down by the fuse box on the driver side.
Any suggestions? Thanks
kcvi3tstyl3 is offline   Reply With Quote
Old 12-05-2008, 12:23 PM   #2
slugo10's Avatar
I always thought if your light is blinking then don't drive car it could damage it. Steady light ok because usually emissions fault.
slugo10 is offline   Reply With Quote
Old 12-05-2008, 05:53 PM   #3
So does anyone know what i can do??? Or what this problem is??
Old 12-05-2008, 06:15 PM   #4
honda_boy23's Avatar
im not quite sure but see if you can get a code reader should tell you whats up.. srry not much help
honda_boy23 is offline   Reply With Quote
Old 12-05-2008, 08:57 PM   #5
ifIexplode's Avatar
Are blinking CEL is a misfire code, Id get it scanned By an OBDII reader.
Could be clogged injector
Plugs
Wires.
ifIexplode is offline   Reply With Quote
Old 12-07-2008, 04:11 PM   #6
so where can i get it scanned at? does anyone else have any ideas or suggestions? Thanks everyone!!!
Old 12-07-2008, 04:49 PM   #7
importdreamer's Avatar
autozone will do it for free. However, the drive there might be a bad idea considering the bogging and loss of compression you think you have. What I would do first is pull the plugs and look for one that is much worse than the others (black, white, broken diode) and also smell them. See if they smell of gas. Also check for any plugs that may have popped off (ie the one on your intake).
importdreamer is offline   Reply With Quote
Old 12-08-2008, 12:29 PM   #8
I did what u guys said and had AutoZone run a check engine light test, and the car threw 2 codes.
P1399
P0135
The second one is said to be an o2 sensor, but what is the second one?
Any help?..thanks
Old 12-08-2008, 12:42 PM   #9
blinking CEL is catalyst related...if you drive the vehicle, you are risking damaging the cat conv, which could get really expensive....get it to a repair shop asap
marcs1337 is offline   Reply With Quote
Old 12-08-2008, 07:28 PM   #10
K i l l a B e e.'s Avatar
dude why dont you search for the codes? gheez.
if you type p1399 in the search function, you will see that it says something about a misfire.
K i l l a B e e. is offline   Reply With Quote
Old 01-26-2009, 11:31 AM   #11
b18c1ej8's Avatar
Default Re: 1999 Honda Civic check engine light blinking!
i had this same issue for months and changed out most of the ignition related parts, found out when i did my compression test that my rings were done on #3 so you might wanna also do a compression test
b18c1ej8 is offline   Reply With Quote
Old 01-26-2009, 12:18 PM   #12
tx_ej8_49's Avatar
You do have a misfire. Blinking light does indicate possible damage to the cat. Start by replacing the cap, wires, plugs, and rotor(About the cheapest thing you can do at this point). While you have the plugs out, compression test it to see what your number are. Are the consistant? No? You have big issues. Yes? The you need to perform a leak-down test. Let us know what happens.
tx_ej8_49 is offline   Reply With Quote
Old 01-26-2009, 02:09 PM   #13
D50boy's Avatar
I had misfires when I had some burned valves. :/
D50boy is offline   Reply With Quote
Old 06-11-2009, 12:41 PM   #14
DOHCIVIC's Avatar
To dig up a old post... I have a blinking light on my 99 civic but its blinking with the enging not even running
DOHCIVIC is offline   Reply With Quote
Old 01-29-2012, 07:11 PM   #15
I know this post is old but i am having similar problems, my cel isnt a constant blinking it only occurs if im doing something as going up a hill and whatever gear im in, the car jumps for a bit and then the cel blinks but goes away ... also it does the same jumping but same as uphill it all depends on what gear im in the elevation and speed and everything .... im just wondering if anyone has any oppions about what could possibly be wrong ... i am doing a mini me swap and ontop of the mini me i was going to do plugs, wires, cap and rotor, water pump,fuel filter, and retime, and if one of those didnt work wasnt sure really what to do.
I also find that the jumping only occurs when the car is warmed up
CivicCity is offline   Reply With Quote
Old 01-29-2012, 07:14 PM   #16
The Grumpiest
grumblemarc's Avatar
Pull the codes the CEL is throwing for starters.
grumblemarc is offline   Reply With Quote
Old 01-30-2012, 05:28 AM   #17
Quote:
I will be checking the codes when i find my reader.
But the thing i dont understand is will the reader even pick up anything since i dont have a cel light, my cel light will only blink if the car jumps for a certain amount of time.
Old 01-30-2012, 06:36 AM   #18
The Grumpiest
How should I know what your reader will pick up? Don't put the cart before the horse. Pull the codes. The next time it starts blinking, pull to the side of the road, keep the car running and pull them.
Old 01-30-2012, 12:22 PM   #19
Problem was solved ... and friend said to check the spark plugs so i replaced them and no more shakeing
Old 01-30-2012, 03:04 PM   #20
Do the EGs have a "Maintenance Required" light like the EKs? And what does it mean when that particular light is illuminated?
Maven is offline   Reply With Quote
Old 04-09-2013, 12:43 AM   #21
how did you manage to fix this problem because a friend of mine have the same problem when we changed the ecu from obd1 or obd2?? msg me.
when car is completely stop the cel would flash and when we drove off the cel would be steady.
code 41 was the only code that i could pull off which was the o2 sensor
jdmkid808 is offline   Reply With Quote
Old 04-12-2013, 05:57 PM   #22
ive got a similar problem, ive got a blinking cel,at idle but as soon as you hit the gas it stops, then if you let it idle it will start blinking again, i just replaced the distributor with a low mileage one from a junkyard, new spark plugs also, i checked the timing and its good and the fuel filter seems to be ok.
just bought this car and its currently not legal, not inspected, and no plates so i cant simply just drive it to advance auto. but i pulled the codes with the service plug and im just getting a code 1 for the o2 sensor. this thing has no power, and hesitates when you hit the throttle and it sounds like a subaru.
any help would be greatly appreciated
rmagnetta is offline   Reply With Quote
Vehicle Speed Sensor Symptoms ccookie66 Honda Accord (1990 - 2002) 13 12-11-2016 08:01 PM
'94 Accord, D4 blinking, engine stalled deutschdragon Honda Accord (1990 - 2002) 13 08-19-2012 06:43 PM
car won't start, check engine light. bstaralways Honda Accord (1990 - 2002) 2 09-04-2007 03:51 PM
code 17 after clutch swap Chrisrey86 Honda CRX / EF Civic (1988 - 1991) 1 05-13-2007 11:16 AM
92 integra problem? frog169 Acura Integra 6 06-09-2006 11:02 PM
Tags
1999, 98, accord, blinking, check, civic, end, engine, flashes, flashing, front, honda, light, popping, sound
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
