1998 Honda Civic and Crank Sensor and Check Engine - Honda-Tech
Old 11-24-2011, 11:41 AM   #1
pityocamptes's Avatar
Default 1998 Honda Civic and Crank Sensor and Check Engine
So my check engine light came on yesterday. I checked the codes and it was a 9 - according to the book the crank sensor. I cleared the code and drove it around for a while it the check engine light did not come back on. Was this a glitch or can I expect to have it come on again? Anything else that may trigger the crank sensor? Thanks!
pityocamptes is offline   Reply With Quote
Old 11-24-2011, 11:44 AM   #2
Default Re: 1998 Honda Civic and Crank Sensor and Check Engine
Code 9 is for the CYP sensor circuit.
Do nothing unless the CEL code returns or there is a performance problem.
Former User is offline   Reply With Quote
Old 11-24-2011, 11:53 AM   #3
Thanks. Is that sensor by the crank? If so I'll probably have someone do it. What do you think the cost on replacing it would be - average cost?
Old 11-24-2011, 11:54 AM   #4
So do you think it was a glitch or something else? why would it trigger a code and then once cleared go away? Could it be a mechanical problem?
Old 11-24-2011, 12:12 PM   #5
It's one of three sensors inside the distributor.
Sometimes codes are thrown and don't return. To avoid fixing something that is not broken, do nothing unless the code returns or there is problem.
Old 11-24-2011, 12:30 PM   #6
if it was the crank sensor code the CEL will blink and show misfires in what ever cylinder that it was in detected. code 9 would be in the distributor and not something u can replace without buying another used or new distributor. all those sensors in the distributor are pinned into the plug and its more trouble then its worth. cutting and splicing is not something u want to do with anything that is voltage sensitive like the distributor sensors. they control alot of how the engine runs.
apexi_rsx is offline   Reply With Quote
Old 11-24-2011, 12:55 PM   #7
I appreciate the input!!! It kind of runs crappy at idle, and I did check the rpms and it right on. Maybe that is just me... at drive speed it runs fine, would that be the performance issue??? Thanks again! If it returns I will post here for a solution. HAPPY THANKSGIVING!!
Old 11-26-2011, 10:21 AM   #8
The cel returned. Now what. Do I need a new dizzy. Can I drive the car. Do I get a honda dizzy or autozone. Not sure how long I can drive it like this. Thanks.
Old 11-26-2011, 10:24 AM   #9
Measure the resistance of the TDC sensor. It should be 350-700 Ohms.
Old 11-26-2011, 10:27 AM   #10
Where is that.
Old 11-26-2011, 10:34 AM   #11
So its not the dizzy.
Old 11-26-2011, 11:34 AM   #12
Ok, went to Autozone and they pulled the code - P1457. It lists the following:
Loose fuel cap
Vapor canister saturated
Failed vent solenoid
Failed purged solenoid
I replaced the cap, original for 13 years. Hopefully that was it. If its the other items where do I start and check for them? Thanks.
Old 12-14-2011, 10:48 AM   #13
Ron or someone else, the check engine light came back on. Where do I start with regards to the emissions issue/CEL? Thanks!
94 Accord EX 5-Speed TDC Sensor Testing moundsostuf Honda Accord (1990 - 2002) 3 06-07-2016 07:15 AM
GSR codes? Need help! 96GS-R-Kaden Acura Integra 27 04-27-2008 04:33 AM
clearing a check engine light brentaction22 Honda Civic / Del Sol (1992 - 2000) 3 05-24-2007 10:28 PM
Need help asap Code 54 Crank Fluctuation Sensor question scoobyghost Honda CRX / EF Civic (1988 - 1991) 7 08-07-2005 09:19 PM
engine check light codes willywonka Honda Accord (1990 - 2002) 8 01-12-2005 06:57 PM
Tags
1998, 2000, 98, civic, cost, crank, crankshaft, crv, cyp, honda, replace, sensor, shaft, terminals, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
