1998 Civic EX Power Window Problem
Car: 1998 Honda Civic EX
Problem: The passenger side window won’t go up or down but the driver window does. The window will go up and down if I put straight power to the window motor.
I checked the 40 amp fuse under the hood and a couple fuses under the dash that said PW thinking it might be power windows. I checked the wiring inside the door and everything seems to be intact.
Also tried another switch on the passenger door. And the driver door switch doesn't put it down either.
Any idea’s what this can be?
Re: 1998 Civic EX Power Window Problem
I'm going to try switching the driver side switch out for one that I know works. I'm thinking maybe its not completing the circuit.
The main switch is in the driver's master switch. See diagram.
Fuses that appear to be good can be bad. Voltage test fuse 10.
https://honda-tech.com/honda-civic-d...fuses-3079359/
had similar problem, but sometimes it would go up and down just VERY VERY slow/weak. checked wiring to door and found my connector where the harness enter the doors was cracked.
SiHatchTurbo
04-01-2012 12:34 PM
BauleyCivic
05-01-2005 04:42 PM
steven975
Honda S2000
05-03-2004 04:37 PM
