1998 Civic EX Cylinder Misfire Troubleshooting - Help Please
Old 03-06-2016, 02:26 PM
SDPGreen's Avatar
Default 1998 Civic EX Cylinder Misfire Troubleshooting - Help Please
Hello all,
CEL codes 071, 072, 074 (no 073).
First symptom, car bogged a bit while accelerating at around 50 mph - no CEL. Gradually bogging & rough idle got worse & then light came on.
I did not check right away, and when I did today, pulled the codes above.
Car currently has 168k miles & is all stock & mostly OEM parts.
At 152k miles (28 months ago), I replaced ignition coil, cap & rotor & plugs.
I'm due to replace plugs & will do today. Wires are probably overdue too, but I would prefer to diagnose rather than just start replacing parts.
I came across the diagnostic advice below, but wanted to check with the Honda-tech community for:
advice on most likely sources of the problem.
advice for the most efficient diagnostic strategy.
Thank you in advance for your thoughts & help.
Best,
David
"How to Test Misfire Codes
(1.6L Honda Civic)"
[URL="http://troubleshootmyvehicle.com/honda/1.6L/how-to-test-a-misfire-condition-1"]
P0301 71 Misfire Cyl. 1 Or Random Misfire
P0302 72 Misfire Cyl. 2 Or Random Misfire
P0303 73 Misfire Cyl. 3 Or Random Misfire
P0304 74 Misfire Cyl. 4 Or Random Misfire
Old 03-06-2016, 02:27 PM
Stancetard Hate Monger
eghatch9295's Avatar
Default Re: 1998 Civic EX Cylinder Misfire Troubleshooting - Help Please
check mechanical timing
Old 03-06-2016, 02:44 PM
SDPGreen's Avatar
Thanks, good tip - I'll try to get a light & do that tomorrow.
Old 03-06-2016, 02:50 PM
mk378's Avatar
Take cap off and look for cracks or burns in the cap rotor or coil. You can't tell much by looking at wires though.
Old 03-07-2016, 06:19 AM
wires can be tested with your multimeter. probably in faqs here, definitely on the googleweb.
Old 03-07-2016, 06:21 AM
mechanical timing requires no light, except maybe a flashlight. look at that, i didnt even have to leave the forum. https://honda-tech.com/honda-civic-d...ssion-2497191/
Old 03-07-2016, 06:30 AM
Former User's Avatar
Start by inspecting and gapping the spark plugs and installing new Honda plug wires. Then go from there.
JDM_G35/EX
Honda Civic (2001 - 2005)
10-28-2015 05:12 AM
jokerstone
04-29-2015 06:24 AM
derjac
05-24-2010 01:46 PM
95TEG
12-07-2006 09:09 AM
LFA Squad :: iTO
06-06-2006 02:43 PM
Quick Reply: 1998 Civic EX Cylinder Misfire Troubleshooting - Help Please
