1996 honda ex with JDM b16a SirII swap running OBD2A P2T ECU
ok im running an odb2a ecu and i have no vtec at all. im assuming that this ecu is very rare cuz i cant find any info on it.i have no cel there is no vtec pressure switch so what other reason would there be for no vtec my wiring is correct to the ecu and i have oil pressure and no dent in oil pan. it dosint lose any power but around 5500-5600 i hear nor feel a difference any help would be appreciated thanks.
does jumping the pressure switch on the ecu to the solenoid help this out being that i have no pressure switch ?
Re: 1996 honda ex with JDM b16a SirII swap running OBD2A P2T ECU
if its a usdm ecu it will be looking for the pressure sensor and won't work without it . and your cel light should be on
Posted from Honda-tech.com App for Android
well when I test the vtec solenoid I hear it click took it off cleaned it still a no go I'm lost in the sauce I recently installed a Bosch o2 and my check engine went off reset my ecu and no cel but could it be the o2 is wired wrong and I would assume if that was the case I would get a cel
Dead CIVIC
07-13-2008 01:16 PM
