1996 civic manual transmission fluid? - Honda-Tech
Old 08-25-2011, 10:38 PM   #1
TOO MUCH TORQUE's Avatar
Default 1996 civic manual transmission fluid?
my friend needs a transmission drain and fill.......is 10w-30 acceptable? what did the user manual call for in this particular year?
honda mtf not accessible for him, but regular motor oil is so if the manual says its okay, we'll use that.
TOO MUCH TORQUE is offline   Reply With Quote
Old 08-25-2011, 10:54 PM   #2
Default Re: 1996 civic manual transmission fluid?
yes but I would order some MTF... I think there was a stipulation for it tho so you will have to look in a helms
Hidenplanvew is offline   Reply With Quote
Old 08-26-2011, 06:35 AM   #3
Bernardi Parts will mail Honda MTF to you.
Former User is offline   Reply With Quote
Old 08-26-2011, 09:22 AM   #4
sde780's Avatar
pennzoil syncromesh
sde780 is offline   Reply With Quote
Old 08-26-2011, 10:44 AM   #5
JDM-sol 89's Avatar
You could always buy GM's syncromesh transmission fluid. But, I always use like castrol's 10w40.
JDM-sol 89 is offline   Reply With Quote
Old 08-26-2011, 11:39 AM   #6
H-T Basic Sponsor
Gearspeed-Performance's Avatar
Quote:
MTF if you can get it.
Regular 10w30 will be fine. You don't need synthetic...just the regular stuff
No need for synchromesh either...Nothing special or magical about it but, can be used.
__________________
Gearspeed Honda/Acura Tranmission Parts and Performance - www.gearspeedwholesale.com - 909-476-7252
*Rebuild Kits*LSD*Carbon Synchros*Gears*Final Drives*Trans building*
Gearspeed-Performance is offline   Reply With Quote
Old 08-26-2011, 11:50 AM   #7
ej1b18c1's Avatar
All above fluids can be used, is always better to use hmtf though.
ej1b18c1 is offline   Reply With Quote
Old 08-26-2011, 05:41 PM   #8
ReDHaTcHyGuy's Avatar
Quote:
Originally Posted by sde780 View Post
pennzoil syncromesh
^^^^this^^^^^
ReDHaTcHyGuy is offline   Reply With Quote
Old 08-26-2011, 06:03 PM   #9
pwebb0207's Avatar
I put regular 5w30 in mine and noticed a grind in 3rd and 4th, along with increased effort to get into all gears. I quickly ordered some Honda MTF. The grinding is gone, and every shift now feels smooth and effortless.
pwebb0207 is offline   Reply With Quote
Old 08-27-2011, 04:02 AM   #10
anothersickhatch's Avatar
Just use Honda MTF.
anothersickhatch is offline   Reply With Quote
Old 08-27-2011, 04:45 PM   #11
syncromesh is better than honda mtf
Old 08-27-2011, 04:58 PM   #12
Quote:
many say to use GM syncomesh ..not Pennzoil syncromesh. i use 10w30 in mine.. but i think next time im going to use honda mtf.. honda's always love their own honda fluids and parts.
apexi_rsx is offline   Reply With Quote
Old 08-27-2011, 06:57 PM   #13
and what makes you say this?
Old 08-27-2011, 07:30 PM   #14
96electronH's Avatar
30 weight oil. I have used pennzoil. And mtf both worked fine.
96electronH is offline   Reply With Quote
Old 08-27-2011, 07:46 PM   #15
96-00 Civic service manual:
96-00 Civic owner's manual:
Old 08-27-2011, 07:52 PM   #16
Quote:
personal experience from working on alot of honda's and doing research...
Old 08-27-2011, 08:21 PM   #17
Seagull Management
94EG8's Avatar
I've tried 10w30 in S40 ('96 - '00) trannys. It didn't work well, no grinding, but it was notchy as hell, put in Honda MTF and it shifted fine. Older S20 trannys work fine with 10W30 though, and a lot of guys that build them everyday say it's better than Honda MTF.
94EG8 is offline   Reply With Quote
Old 08-27-2011, 11:58 PM   #18
can you point me in the right direction to find this research? Plenty of people have had plenty of experience with Honda's that may not find Syncromesh to be better than Honda MTF. If the OP wants to try both, then he can form his own opinions. Honda recommends MTF for a reason and I guarantee that they have had the most experience with Honda transmissions.
Old 08-28-2011, 06:32 AM   #19
sde780's Avatar
Quote:
GM syncromesh says it's "friction modified", while Pennzoil syncromesh doesn't. I noticed no difference between the two. However, GM syncromesh is much more expensive.
From a mod on here:
Quote:
Originally Posted by PatrickGSR94 View Post
Used to use Honda MTF back in the day (early 2000's). Switched to GM Synchromesh Friction Modified in 2003 and never looked back. Been using it ever since, changed every 25K-50K miles, and transmission still shifts smooth as ever on all original internals and 295K miles on it, even with the short throw shifter I've had for over 200K miles.
Buddy of mine used to work at a Chevy dealer, and I bought the last 6 quarts of FM they had a couple years back for only 50 bucks.
Check out this thread:
http://honda-tech.com/showthread.php?t=641177
Various replies from other threads:
Quote:
Originally Posted by blackeg View Post
i have absolutely no complaints about syncromesh. gm syncromesh fixed a slight grind into 3rd on my old car, and im currently running it in my new car with no problems.
Quote:
Originally Posted by BlueIntegraBoy View Post
Quote:
Originally Posted by illifili
where can u get this stuff?
I just bought some today from my Chevy dealer. Part number 12377619. I put it in and I noticed a smoothness in shifting immediately. I have to wait to break it in to fix my 3rd gear grind at higher RPMs. The shifter feels similar to my Type-S cable shifter.
I'm not saying it's miracle tranny elixir, but from what I read (and experienced) it's pretty good. I tried Honda MTF and it shifted like before I changed the fluid. With Syncromesh, shifting was much smoother. But say what you like, I'm not forcing you to like Syncromesh.
Old 08-28-2011, 06:35 AM   #20
v8killaz's Avatar
I use 10w30 strictly . my buddy uses it in his far trans he's had for 20 years. and that's the best shifting trans I've ever ran. we have driven the car clutchless many time. he has daily drove it without a clutch pedal thing will shift without the clutch flawlessly
v8killaz is offline   Reply With Quote
Old 08-28-2011, 08:19 AM   #21
Kista20's Avatar
Honda mtf is the best you can use and their new stuff is a lot better than the old formula. I've used the old stuff before and wasn't too happy with itin my 97 hx and it caused notchy shifting then I switched to the pennzoil syncromesh and it was way better and the shifts were smooth. I have put the new mtf into my 99 and it's been great so far.
Kista20 is offline   Reply With Quote
Old 08-29-2011, 06:19 AM   #22
yea i should have mentioned that their new stuff is suppose to be alot better, i was refering to the old formula as not being as good as syncromesh... they developed a new formula when they had all those problems with the trannys in the new Si's and a few others.. i hear its alot better.. havent tried it yet..
Old 08-29-2011, 06:40 AM   #23
Risky Business
BauleyCivic's Avatar
Another vote for GM synchromesh here.
Pennzoil synchromesh is gear oil...Honda transmissions aren't designed to use gear oil.
BauleyCivic is offline   Reply With Quote
Old 08-29-2011, 06:46 AM   #24
sde780's Avatar
^just to clarify, you need the FRICTION MODIFIED if you get GM syncromesh. I'll try the new honda mtf next week and update, I'm using pennzoil syncromesh with a slight 2nd gear grind above 6k rpm
Old 09-02-2011, 07:24 PM   #25
Kista20's Avatar
friction modified only if your running an lsd. I've been running the pennzoil syncromesh for over 60k miles in my y5's tranny and I've had zero issues with it.
And pennzoil syncromesh is not gear oil it is the same thing as gm's regular syncromesh only you don't have to get bent over to grab your ankles by the dealer.
auto transmission to manual 76 camaro car Honda Accord (1990 - 2002) 6 06-12-2016 06:27 PM
89' hatch swap from auto to manual 98bucket Honda CRX / EF Civic (1988 - 1991) 5 09-25-2015 09:17 AM
auto to manual transmission mount PabloM For Sale 1 03-23-2014 07:16 AM
best manual transmission fluid dumpedcivicej1 Tech / Misc 12 01-10-2013 07:07 AM
Auto vs. Manual transmission jascon General Discussion and Debate 6 11-02-2004 12:56 PM
Tags
10w, 1996, 30, 95, 97, add, civic, del, fluid, honda, manual, oil, slipping, tranny, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
